A look at the die of the 8086 processor
The Intel 8086 microprocessor was introduced 42 years ago this month,1 so I made some high-res die photos of the chip to celebrate. The 8086 is one of the most influential chips ever created; it started the x86 architecture that still dominates desktop and server computing today. By looking at the chip's silicon, we can see the internal features of this chip.
The photo below shows the die of the 8086. In this photo, the chip's metal layer is visible, mostly obscuring the silicon underneath. Around the edges of the die, thin bond wires provide connections between pads on the chip and the external pins. (The power and ground pads each have two bond wires to support the higher current.) The chip was complex for its time, containing 29,000 transistors.
Die photo of the 8086, showing the metal layer. Around the edges, bond wires are connected to pads on the die. Click for a large, high-resolution image.
Looking inside the chip
To examine the die, I started with the 8086 integrated circuit below. Most integrated circuits are packaged in epoxy, so dangerous acids are necessary to dissolve the package. To avoid that, I obtained the 8086 in a ceramic package instead. Opening a ceramic package is a simple matter of tapping it along the seam with a chisel, popping the ceramic top off.
The 8086 chip, in 40-pin ceramic DIP package.
With the top removed, the silicon die is visible in the center. The die is connected to the chip's metal pins via tiny bond wires. This is a 40-pin DIP package, the standard packaging for microprocessors at the time. Note that the silicon die itself occupies a small fraction of the chip's size.
The 8086 die is visible in the middle of the integrated circuit package.
Using a metallurgical microscope, I took dozens of photos of the die and stitched them into a high-resolution image using a program called Hugin (details). The photo at the beginning of the blog post shows the metal layer of the chip, but this layer hid the silicon underneath.
Under the microscope, the 8086 part number is visible as well as the copyright date. A bond wire is connected to a pad. Part of the microcode ROM is at the top.
For the die photo below, the metal and polysilicon layers were removed, showing the underlying silicon with its 29,000 transistors.2 The labels show the main functional blocks, based on my reverse engineering. The left side of the chip contains the 16-bit datapath: the chip's registers and arithmetic circuitry. The adder and upper registers form the Bus Interface Unit that communicates with external memory, while the lower registers and the ALU form the Execution Unit that processes data. The right side of the chip has control circuitry and instruction decoding, along with the microcode ROM that controls each instruction.
Die of the 8086 microprocessor showing main functional blocks.
One feature of the 8086 was instruction prefetching, which improved performance by fetching instructions from memory before they were needed. This was implemented by the Bus Interface Unit in the upper left, which accessed external memory. The upper registers include the 8086's infamous segment registers, which provided access to a larger address space than the 64 kilobytes allowed by a 16-bit address. For each memory access, a segment register and a memory offset were added to form the final memory address. For performance, the 8086 had a separate adder for these memory address computations, rather than using the ALU. The upper registers also include six bytes of instruction prefetch buffer and the program counter.
The lower-left corner of the chip holds the Execution Unit, which performs data operations. The lower registers include the general-purpose registers and index registers such as the stack pointer. The 16-bit ALU performs arithmetic operations (addition and subtraction), Boolean logical operations, and shifts. The ALU does not implement multiplication or division; these operations are performed through a sequence of shifts and adds/subtracts, so they are relatively slow.
Microcode
One of the hardest parts of computer design is creating the control logic that tells each part of the processor what to do to carry out each instruction. In 1951, Maurice Wilkes came up with the idea of microcode: instead of building the control logic from complex logic gate circuitry, the control logic could be replaced with special code called microcode. To execute an instruction, the computer internally executes several simpler micro-instructions, which are specified by the microcode. With microcode, building the processor's control logic becomes a programming task instead of a logic design task.
Microcode was common in mainframe computers of the 1960s, but early microprocessors such as the 6502 and Z-80 didn't use microcode because early chips didn't have room to store microcode. However, later chips such as the 8086 and 68000, used microcode, taking advantage of increasing chip densities. This allowed the 8086 to implement complex instructions (such as multiplication and string copying) without making the circuitry more complex. The downside was the microcode took a large fraction of the 8086's die; the microcode is visible in the lower-right corner of the die photos.3
A section of the microcode ROM. Bits are stored by the presence or absence of transistors. The transistors are the small white rectangles above and/or below each dark rectangle. The dark rectangles are connections to the horizontal output buses in the metal layer.
The photo above shows part of the microcode ROM. Under a microscope, the contents of the microcode ROM are visible, and the bits can be read out, based on the presence or absence of transistors in each position. The ROM consists of 512 micro-instructions, each 21 bits wide. Each micro-instruction specifies movement of data between a source and destination. It also specifies a micro-operation which can be a jump, ALU operation, memory operation, microcode subroutine call, or microcode bookkeeping. The microcode is fairly efficient; a simple instruction such as increment or decrement consists of two micro-instructions, while a more complex string copy instruction is implemented in eight micro-instructions.3
History of the 8086
The path to the 8086 was not as direct and planned as you might expect. Its earliest ancestor was the Datapoint 2200, a desktop computer/terminal from 1970. The Datapoint 2200 was before the creation of the microprocessor, so it used an 8-bit processor built from a board full of individual TTL integrated circuits. Datapoint asked Intel and Texas Instruments if it would be possible to replace that board of chips with a single chip. Copying the Datapoint 2200's architecture, Texas Instruments created the TMX 1795 processor (1971) and Intel created the 8008 processor (1972). However, Datapoint rejected these processors, a fateful decision. Although Texas Instruments couldn't find a customer for the TMX 1795 processor and abandoned it, Intel decided to sell the 8008 as a product, creating the microprocessor market. Intel followed the 8008 with the improved 8080 (1974) and 8085 (1976) processors. (I've written more about early microprocessors here.)
Datapoint 2200 computer. Photo courtesy of Austin Roche.
In 1975, Intel's next big plan was the 8800 processor designed to be Intel's chief architecture for the 1980s. This processor was called a "micromainframe" because of its planned high performance. It had an entirely new instruction set designed for high-level languages such as Ada, and supported object-oriented programming and garbage collection at the hardware level. Unfortunately, this chip was too ambitious for the time and fell drastically behind schedule. It eventually launched in 1981 (as the iAPX 432) with disappointing performance, and was a commercial failure.
Because the iAPX 432 was behind schedule, Intel decided in 1976 that they needed a simple, stop-gap processor to sell until the iAPX 432 was ready. Intel rapidly designed the 8086 as a 16-bit processor somewhat compatible with the 8-bit 8080,4 released in 1978. The 8086 had its big break with the introduction of the IBM Personal Computer (PC) in 1981. By 1983, the IBM PC was the best-selling computer and became the standard for personal computers. The processor in the IBM PC was the 8088, a variant of the 8086 with an 8-bit bus. The success of the IBM PC made the 8086 architecture a standard that still persists, 42 years later.
Why did the IBM PC pick the Intel 8088 processor?7 According to Dr. David Bradley, one of the original IBM PC engineers, a key factor was the team's familiarity with Intel's development systems and processors. (They had used the Intel 8085 in the earlier IBM Datamaster desktop computer.) Another engineer, Lewis Eggebrecht, said the Motorola 68000 was a worthy competitor6 but its 16-bit data bus would significantly increase cost (as with the 8086). He also credited Intel's better support chips and development tools.5
In any case, the decision to use the 8088 processor cemented the success of the x86 family. The IBM PC AT (1984) upgraded to the compatible but more powerful 80286 processor. In 1985, the x86 line moved to 32 bits with the 80386, and then 64 bits in 2003 with AMD's Opteron architecture. The x86 architecture is still being extended with features such as AVX-512 vector operations (2016). But even though all these changes, the x86 architecture retains compatibility with the original 8086.
Transistors
The 8086 chip was built with a type of transistor called NMOS. The transistor can be considered a switch, controlling the flow of current between two regions called the source and drain. These transistors are built by doping areas of the silicon substrate with impurities to create "diffusion" regions that have different electrical properties. The transistor is activated by the gate, made of a special type of silicon called polysilicon, layered above the substrate silicon. The transistors are wired together by a metal layer on top, building the complete integrated circuit. While modern processors may have over a dozen metal layers, the 8086 had a single metal layer.
Structure of a MOSFET in the integrated circuit.
The closeup photo of the silicon below shows some of the transistors from the arithmetic-logic unit (ALU). The doped, conductive silicon has a dark purple color. The white stripes are where a polysilicon wire crossed the silicon, forming the gate of a transistor. (I count 23 transistors forming 7 gates.) The transistors have complex shapes to make the layout as efficient as possible. In addition, the transistors have different sizes to provide higher power where needed. Note that neighboring transistors can share the source or drain, causing them to be connected together. The circles are connections (called vias) between the silicon layer and the metal wiring, while the small squares are connections between the silicon layer and the polysilicon.
Closeup of some transistors in the 8086. The metal and polysilicon layers have been removed in this photo. The doped silicon has a dark purple appearance due to thin-film interference.
The 8086 was intended as a temporary stop-gap processor until Intel released their flagship iAPX 432 chip, and was the descendant of a processor built from a board full of TTL chips. But from these humble beginnings, the 8086's architecture (x86) unexpectedly ended up dominating desktop and server computing until the present.
Although the 8086 is a complex chip, it can be examined under a microscope down to individual transistors. I plan to analyze the 8086 in more detail in future blog posts8, so follow me on Twitter at @kenshirriff for updates. I also have an RSS feed. Here's a bonus high-resolution photo of the 8086 with the metal and polysilicon removed; click for a large version.
Die photo of the Intel 8086 processor. The metal and polysilicon have been removed to reveal the underlying silicon.
  1. The 8086 was released on June 8, 1978. ↩
  2. To expose the chip's silicon, I used Armour Etch glass etching cream to remove the silicon dioxide layer. Then I dissolved the metal using hydrochloric acid (pool acid) from the hardware store. I repeated these steps until the bare silicon remained, revealing the transistors. ↩
  3. The designers of the 8086 used several techniques to keep the size of the microcode manageable. For instance, instead of implementing separate microcode routines for byte operations and word operations, they re-used the microcode and implemented control circuitry (with logic gates) to handle the different sizes. Similarly, they used the same microcode for increment and decrement instructions, with circuitry to add or subtract based on the opcode. The microcode is discussed in detail in New options from big chips and patent 4449184. ↩↩
  4. The 8086 was designed to provide an upgrade path from the 8080, but the architectures had significant differences, so they were not binary compatible or even compatible at the assembly code level. Assembly code for the 8080 could be converted to 8086 assembly via a program called CONV-86, which would usually require manual cleanup afterward. Many of the early programs for the 8086 were conversions of 8080 programs. ↩
  5. Eggebrecht, one of the original engineers on the IBM PC, discusses the reasons for selecting the 8088 in Interfacing to the IBM Personal Computer (1990), summarized here. He discussed why other chips were rejected: IBM microprocessors lacked good development tools, and 8-bit processors such as the 6502 or Z-80 had limited performance and would make IBM a follower of the competition. I get the impression that he would have preferred the Motorola 68000. He concludes, "The 8088 was a comfortable solution for IBM. Was it the best processor architecture available at the time? Probably not, but history seems to have been kind to the decision." ↩
  6. The Motorola 68000 processor was a 32-bit processor internally, with a 16-bit bus, and is generally considered a more advanced processor than the 8086/8088. It was used in systems such as Sun workstations (1982), Silicon Graphics IRIS (1984), the Amiga (1985), and many Apple systems. Apple used the 68000 in the original Apple Macintosh (1984), upgrading to the 68030 in the Macintosh IIx (1988), and the 68040 with the Macintosh Quadra (1991). However, in 1994, Apple switched to the RISC PowerPC chip, built by an alliance of Apple, IBM, and Motorola. In 2006, Apple moved to Intel x86 processors, almost 28 years after the introduction of the 8086. Now, Apple is rumored to be switching from Intel to its own ARM-based processors. ↩
  7. For more information on the development of the IBM PC, see A Personal History of the IBM PC by Dr. Bradley. ↩
  8. The main reason I haven't done more analysis of the 8086 is that I etched the chip for too long while removing the metal and removed the polysilicon as well, so I couldn't photograph and study the polysilicon layer. Thus, I can't determine how the 8086 circuitry is wired together. I've ordered another 8086 chip to try again. ↩
20 comments:
Terry Smith said...
Wow Awesome thanks!
Kevin said...
Fantastic work Ken. Thank you for taking the time to write this up. I was a teenager in the 70s and watched the development of the personal computer up close. Your articles are a fun romp through those days
Ken Rose said...
Always fascinating. Thanks.
A request for future chips: I would love to see a teardown of a 68000
Mark Jeronimus said...
I don't know what you mean by "6502 and Z-80 didn't use microcode" because they have a microcode ROM and it's one of the things that allows 'unofficial' opcode tricks.
The Happy Engineer said...
No.6502 does not have microcode. A logic array is decoding the instructions and unofficial opcodes are there as a byproduct of the array not covering all possible combinations.
"infamous segment registers".
Oh yes. I worked as a lowly student writing 8086 code in the 80's. It took maybe three attempts for my boss to make me understand the concept. I just couldn't believe something so programmatically ugly actually got built in silicon.
Later I became a 68000 man (much, much x millions) nicer to program - but actually to my chagrin, not really faster. Of course we all know now that ARM blew them both out of the water...
I still occasionally work in x64 assembler, and it isn't elegant is it, but luckily those segment registers are long gone... Except they aren't I believe I've seen them in gdb - kernel level stuff perhaps? I tend to do application level.
Anyway, thanks for the most enjoyable article, I truly love reading these.
Oh, and Ken Rose above, suggest micrographs of the 68000. Please!
Regards.
Great article. I am a totally noob in electronics (just finished nandgame.com HAHA ) but can you enlighten us with further details of the layout of the microcode? Where are the 512 different instructions or the 21 instruction length visible? I see only 56x84 "thingies" and above some other structures, but I cannot bind this together to find these 512/21 numbers.. or am I totally wrong here?
Best regards,
Peter
Nick Alcock said...
In 64-bit long mode, there are two segment registers left: FS and GS. They're usually used for thread-local storage, per-CPU data or similar things that actually *need* the addend stuff that segment registers give you (on Linux, FS is usually used for per-thread data in userspace and GS for per-CPU data in kernelspace, but this is just one OS and others can do other things with them). The other four "historical" segment registers are hardwired to base 0, limit 2^64.
But of course all the machinery to handle them is still there on the silicon -- it has to be, because in non-long mode all that stuff still works. Of course on modern processors it doesn't work internally anything like the way it worked on the 8086: the segment registers are indexes into tables which eventually yield a data structure containing the high bits of the address, limit, privilege info etc etc etc. This is *still true even in real mode*: it's just that on transition to real mode the operating system (or, at boot, the BIOS/firmware) nails the address, limit etc to 8086-compatible values. You can use other values instead, which gives you 'unreal mode' (which is really 'half of the way to virtual 8086 mode', since this trick is a largish part of how virtual 8086 mode worked internally). There is astonishingly little difference between real and protected mode from the perspective of a 386+'s operation. Long mode makes far larger changes.
Anonymous: the microcode is logically 512x21, but it is constructed 4 words wide so it is physically 128x84. (A long skinny ROM is less efficient to build than one that is closer to square.) The 84 rows you see are 21*4. Unless you look closely, you'll see 64 structure, not 128, because each pair of transistors shares a ground line. I plan to write about the microcode in detail at some point.
Shai Berger said...
Great work!
@Happy Engineer: You answered the guy saying Z80 and 6502 have microcode by stating the 6502 does not. Does that meat that you somehow view the PLA structures used in the Z80 as microcode?
Best Regards
/Sven Ekeberg
Thank you for your very interesting posts Ken!! I have always been curious about history of CPUs and your work is really helpful!
can said...
Thanks for this great post.
Wonderful and very illustrative article, Ken. Great work.
Kilian Hekhuis said...
I was wondering how the instruction pointer is incremented. I don't think it can use the ALU, as it needs to be incremented first, before e.g. a conditional jump that needs the current IP to be incremented already. And looking at the instruction timing, it also seems the ALU can't be involved? Still you'd need some kind of ALU-like structure, as you need a variable constant added (since variable instruction length).
黄禄轩 said...
I have built some part of 8086 in minecraft, and I found there is too many ways to achieve the same behavior as the real chip. I made some proper guess according to the uCode ROM and the timing of the real chip, and it can run exactly as same as the real chip, but I still perfer to make the design as close to the real chip as I can. So can you find some way to take some photo of polysilicon around group decoder ROM and ALU ROM?
Ken, Thanks for the web page. I actually worked at Intel on circuitry inside the 8086 chip "back in the day" for a short while to improve its speed performance. Maybe one or two of those transistors you zoomed in on are mine. My supervisor designed about half of it.
One comment: you noted the die does not occupy the whole "chip." That's not quite right. The chip is the die - they are the same thing. More precisely, you could say "the chip (or die) does not occupy the whole 'package'", the package being the black plastic (or ceramic) thing with the legs sticking out.
IIRC the "gate length" of the transistors on the 8086 was about 2.5 or 3 micrometers (millions of a meter) - the smallest feature on the chip. In today's advanced technology, gate lengths are about 1000 (!!!) times smaller - on the order of 5 (or less?) nanometers (billions of a meter) long. That takes a lot of high tech equipment - a chip fabrication plant ("wafer fab") can cost $20 billion these days. Not for the faint of heart.
JCS
Thanks for the web page. I actually worked at Intel on this 8086 chip "back in the day" for a short while to improve its speed performance. Maybe one or two of the transistors you zoomed in on are mine, especially if they are near the metal pads on the outside where the bond wires were connected. My supervisor designed about half of the chip.
One comment: you noted the "die is smaller than the chip". That's not quite right - the chip is the die. You could say the chip (or die) is much smaller than the "package" - the black thing with the metal legs sticking out.
The smallest dimension on the 8086 back then (gate length) was about 2.5 or 3 micrometers (millionths of a meter). Today on advanced chips they are about 1000 X smaller, maybe 5 nanometers (billionths of a meter. That takes a lot of high tech - a chip plant ("wafer fab") can cost $20 Billion - about $70 for every person in the US if I did my math right. Definitely not for the faint of heart.
JCS
Thanks for the web page. It brings back a lot of memories. I actually worked at Intel on this 8086 chip "back in the day" for a short while to improve its speed performance. Maybe a few of the transistors you zoomed in on are mine, especially if they are near the metal pads on the outside where the bond wires were connected. My supervisor designed a large fraction of the chip.
One minor detail: you noted the "die is smaller than the chip". That's not quite the right language - the chip is the die. You could say the chip (or die) is much smaller than the "package" - the black thing with the metal legs sticking out.
The smallest dimension on the 8086 back then (gate length) was about 2.5 or 3 micrometers (millionths of a meter). Today on advanced chips they are about 1000 X smaller, maybe 5 nanometers (billionths of a meter) or even less. That takes a lot of high tech - a chip plant ("wafer fab") can cost $20 Billion - about $70 for every person in the US if I did my math right. Definitely not for the faint of heart.
JCS
Thank you so much for this work, i am doing my B.Tech right now and it helps a lot understanding the processor architecture. These works keeps the curiosity alive. AMAZING!!
