Understanding and repairing the power supply from a 1969 analog computer
We recently started restoring a vintage1 analog computer. Unlike a digital computer that represents numbers with discrete binary values, an analog computer performs computations using physical, continuously changeable values such as voltages. Since the accuracy of the results depends on the accuracy of these voltages, a precision power supply is critical in an analog computer. This blog post discusses how this computer's power supply works, and how we fixed a problem with it. This is the second post in the series; the first post discussed the precision op amps in the computer.
The Model 240 analog computer from Simulators Inc. was a "precision general purpose analog computer" for the desk top, with up to 24 op amps. (This one has 20 op amps.)
Analog computers used to be popular for fast scientific computation, especially differential equations, but pretty much died out in the 1970s as digital computers became more powerful. They were typically programmed by plugging cables into a patch panel, yielding a spaghetti-like tangle of wires. In the photo above, the colorful patch panel is in the middle. Above the patch panel, 18 potentiometers set voltage levels to input different parameters. A smaller patch panel for the digital logic is in the upper right.
The power supply
The computer uses two reference voltages: +10 V and -10 V, which the power supply must generate with high accuracy. (Older, tube-based analog computers typically used +/- 100 V references.) The power supply also provides regulated +/- 15 V to power the op amps, power for the various relays in the computer, and power for the lamps.
The power supply in the bottom section of the analog computer. The transformer/rectifier section is on the left and the regulator card cage is on the right. Wiring harnesses on top of the power supply connect it to the rest of the computer.
The photo above shows the power supply in the lower back section of the analog computer. The power supply is more complex than I expected. The section on the left converts line-voltage AC into low-voltage AC and DC. These outputs go to the card cage on the right, which has 8 circuit boards that regulate the voltages. The complex wiring harnesses on top of the power supply provide power to the five analog computation modules above the power supply as well as the rest of the computer.
With a vintage computer, it's important to make sure the power supply is working properly, since if it is generating the wrong voltages, the results could be catastrophic. So we proceed methodically, first checking the components in the power supply, then testing the power supply outputs while disconnected from the rest of the computer, and finally powering up the whole computer.
The transformer / rectifier section
We started by removing the power supply from the computer, and disconnecting the two halves. The left half of the power supply (below) produces four unregulated DC outputs and a low-voltage AC output. In contains two large power transformers, four large filter capacitors, stud rectifiers (upper back), smaller diodes (front right), and fuses. This is a large and very heavy module because of the transformers.2 The smaller transformer powers the lamps and relays, while the larger transformer powers the +15 and -15 volt supplies as well as the oscillator. Presumably, using separate transformers prevents noise and fluctuations from the lamps and relays from affecting the precision reference supplies.
This section of the power supply reduces the line-voltage AC to low-voltage DC and AC.
One concern with old power supplies is that the electrolytic capacitors can dry out and fail over time. (These capacitors are the large cylinders above.) We measured the capacitance and resistance of the large capacitors (using Marc's vintage HP LCR meter) and they tested okay. We also checked the input resistance of the power supply to make sure there weren't any obvious shorts; everything seemed fine.
We removed all the cards from the card cage, cautiously plugged in the power supply, and... nothing at all happened. For some reason, no AC voltage was getting to the power supply. The fuse was an obvious suspect, but it was fine. Carl asked about the power switch on the control panel, and we figured out that the switch was connected to the power supply via the socket labeled "CP" (below). We added a jumper, powered up the supply, and this time found the expected DC voltages from the module.
The side of the power supply has three twist-lock AC sockets labeled "FAN", "DVM-LOGIC", and "CP" (control panel). The "DVM-LOGIC" socket powers a 5-volt supply for the digital logic, which we still need to repair.
The regulator cards
Next, we tested the power supply's various cards individually. The power supply has four regulator cards generating "lamp voltage", "+15", "-15", and "relay voltage". The purpose of a regulator card is to take an unregulated DC voltage from the transformer module and reduce it to the desired output voltage.
We hooked up the regulator cards using a bench power supply as input to make sure they were working properly. We tweaked the potentiometer on the +15 V regulator to get exactly 15 V output. The -15 V regulator seemed temperamental and the voltage jumped around when we adjusted it. I suspected a dirty potentiometer, but it settled down to a stable output (narrator: this is foreshadowing). We don't know what the lamp and relay voltages are supposed to be, and they're not critical, so we left those boards unadjusted.
One of the voltage regulator cards. A large power transistor is attached to the heat sink.
The photo above shows one of the regulator cards; you might think it has a lot of components just to regulate a voltage. The first voltage regulator chip was created in 1966, so this computer uses a linear regulator built from individual components instead. The large metal transistor on the heat sink is the heart of the voltage regulator; it acts kind of like a variable resistor to control the output. The rest of the components provide the control signal to this transistor to produce the desired output. A Zener diode (yellow and green stripes on the right) acts as the voltage reference, and the output is compared to this reference. A smaller transistor generates the control signal for the power transistors. In the lower right, a multi-turn potentiometer is used to adjust the voltage output. The larger capacitors (metal cylinders) filter the voltage, while the smaller capacitors ensure stability. Most power supply of just a few years later would replace all of these components (except the filter capacitors) with a voltage regulator IC.
The chopper oscillator
The precision op amps in the analog computer use a chopper circuit for better DC performance, and the chopper requires 400 Hertz pulses. These pulses are generated by the oscillator board in the power supply (called the gate for some reason). We powered up the board separately to test it, and found it produced 370 Hz, which seemed close enough.
The gate card provides 400 Hertz oscillations to control the op amp choppers.
The circuitry of this card is somewhat bizarre, and not what I was expecting on an oscillator card. The left side has three large capacitors and three diodes, powered by low-voltage AC from the transformer. After puzzling over this for a bit, I determined it was a full-wave voltage doubler, producing DC at twice the voltage of the AC input. I assume that the chopper pulses needed to be higher voltage than the computer's +15 volt supply, so they used this voltage doubler to get enough voltage swing.
The oscillator itself (right side of the card), uses one NPN transistor as an oscillator, and another NPN transistor as a buffer. It took me a while to figure out how a single-transistor oscillator works. It turns out to be a phase-shift oscillator; the three white capacitors in the middle of the board shift the signal 180°; inverting it causes oscillation.
The op amps
Calculations in the analog computer are referenced to +10 volt and -10 volt reference voltages, so these voltages need to be very accurate. The regulator cards produce fairly stable voltages, but not good enough. (While testing the regulator cards, I noticed that the output voltage shifted noticeably as I changed the input voltage.) To achieve this accuracy, the reference voltages are generated by op amp circuits, built from two op amp boards and a feedback network card.
An op amp card. This card has a single input on the right. It uses a round metal-can op amp IC, but the chopper circuitry improves performance.
Somewhat surprisingly, the op amp cards used in the power supply are exactly the same as the precision op amps used in the analog computer itself. Back in 1969, op amp integrated circuits weren't accurate enough for the analog computer, so the designers of this analog computer combined an op amp chip with a chopper circuit and many other parts to create a high-performance op ap card. I described the op amp cards in detail in the first post, so I won't go into more detail here.
The network card
The network card has two jobs. First, it has precision resistors to create the feedback networks for the power supply op amps. Second, it has two power transistors (circular metal components below) that buffer the reference voltages from the op amp for use by the rest of the computer.
The network card. The two connectors on the left are attached to the op amp inputs.
One of the problems with an analog computer is that the results are only as accurate as the components. In other words, if the 10 volt reference is off by 1%, your answers will be off by 1%. The result is that analog computers need expensive, high-precision resistors. (In contrast, the voltages in a digital computer can drift a lot, as long as a 0 and a 1 can be distinguished. This is one reason why digital computers replaced analog computers.) Typical resistors have a tolerance of 20%, which means the resistance can be up to 20% different from the indicated value. More expensive resistors have tolerance of 10%, 5%, or even 1%. But the resistors on this board have tolerance of 0.01%! (These resistors are the pink cylinders.) The two large resistors on the left are 15Ω "Brown Devil" power resistors. They protect the voltage outputs in case someone plugs the wrong wire into the patch panel and shorts an output, which would be easy to do.
The network card receives an adjustment voltage from the control panel, and also has multi-turn potentiometers on the right for adjustment (like the regulator cards). The green connectors are used to connect the network card to the op amp cards. (The op amps have a separate connector for the input, to reduce electrical noise.)
Powering it up and fixing a problem
Finally, we put all the power supply boards back in the cabinet, put the power supply back in the computer, and powered up the chassis (but not the analog computer modules). Some of the indicator lights on the control panel lit up and the +15 V supply showed up on the meter. However, the -15 V supply wasn't giving any voltage, and the op amp overload lights were illuminated on the front panel, and the reference voltages from the op amps weren't there. The bad -15 V supply looked like the first thing to investigate, since without it, the op amp boards wouldn't work.
I removed the working +15 regulator and failing -15 regulator from the card cage and tested them on the bench. Conveniently, both boards are identical, so I could easily compare signals on the two boards. (Modern circuits typically use special regulators for negative voltage outputs, but this power supply used the same regulator for both.) The output transistor on the bad board wasn't getting any control signal on its base, so it wasn't producing any output. Tracing the signals back, I found the transistor generating this signal wasn't getting any voltage. This transistor was powered directly from the connector, so why wasn't any voltage getting to the transistor?
A regulator board was failing due to loose screws (red arrows). The circuit was powered through the thick bottom PCB trace and then
current passed through the heat sink from the lower screw to the upper screw.
A regulator board was failing due to loose screws (red arrows). The circuit was powered through the thick bottom PCB trace and then current passed through the heat sink from the lower screw to the upper screw.
I studied the printed circuit board and noticed that there wasn't a PCB trace between the transistor and the connector! Instead, part of the current path was through the heat sink. The heat sink was screwed down to the PCB, making a connection between the two red arrows above. After I tightened all the screws, the board worked fine.
The analog computer with the plugboard and sides removed to show the internal circuitry. The power supply is in the lower back section. One module has been removed and placed in front of the computer.
We put the boards back in, powered up the chassis, and this time the voltages all seemed to be correct. The op amp overload warning lights remained off; the warning light went on before because the op amps couldn't operate with one voltage missing. The next step is to power up the analog circuitry modules and test them. We also need to repair the separate 5-volt power supply used by the digital logic since we found some bad capacitors that will need to be replaced. So those are tasks for the next sessions.
Follow me on Twitter @kenshirriff to stay informed of future articles. I also have an RSS feed.
  1. The computer's integrated circuits have 1968 and 1969 date codes on them, so I think the computer was manufactured in 1969. ↩
  2. Most modern power supplies are switching power supplies, so they are much smaller and lighter than linear power supplies like the one in the analog computer. (Your laptop charger, for instance, is a switching power supply.) Back in this era, switching power supplies were fairly exotic. However, linear power supplies are still sometimes used since they have less noise than switching power supplies. ↩
TROS: How IBM mainframes stored microcode in transformers
I recently came across a Transformer Read-Only Storage (TROS) module that stored microcode in an IBM System/360 mainframe computer. This unusual storage mechanism used a stack of Mylar sheets to hold 15,360 bits, equivalent to 1920 bytes. By modern standards, this is an absurdly small amount of data, but in 19641, semiconductor read-only memory chips weren't available, so using Mylar sheets for storage was a reasonable solution. In this blog post, I explain how the TROS module worked and its role in the success of the IBM System/360.
A TROS module, about 15" (39 cm) long. On the left, 60 transformers pass through the stack of 128 Mylar sheets. (Only the square ends of the transformers are visible.) The sheets are connected to the diode boards on the right. The TROS module is connected to the rest of the computer through the connector cables at the back.
How TROS worked: transformers and current pulses
The diagram below shows the concept behind TROS, simplified to two words of three bits each. The three transformers (square rings) each have a sense winding that generates one bit of output. Each word (A or B) has a drive line that passes either through a transformer (for a 1 bit) or around a transformer (for a 0 bit). In the diagram, drive line B (red) is activated by a current pulse. It generates a pulse (blue) from the second and third transformers, generating the bits 011 for Word B. The wiring for Word A, on the other hand, generates the bits 101. Storing more words is accomplished by threading more drive lines through (or around) the transformers, one for each word. Any bit pattern can be stored, depending on how the drive line is wired.
Simplified diagram of TROS storage. Based on Model 40 Functional Units.
The actual TROS module has 60 transformers and 256 drive lines, so it held 256 words of 60 bits. Physically threading 256 wires through transformers would be difficult, so the TROS module used a clever technique to make the wiring easy to assemble or modify. The wiring was printed on sheets of Mylar (called tapes), essentially a flexible printed circuit board. Each tape had two loops of wiring (called word lines) that either went through or around the transformers, so 128 Mylar tapes provided the wiring for 256 words.
A Mylar tape, holding 120 bits of data. It consists of two wire loops, connected to the four pins at the bottom.
The Mylar tapes were stacked on the 60 transformers as shown below. Each of the 60 transformers consisted of a U-shape with both arms passing through the stack of 128 tapes. In this way, the Mylar tapes efficiently created the wiring through and around the transformers, rather than threading individual wires.
Structure of the transformers, viewed from underneath. Each transformer consists of a U-piece that goes through the tapes, and an I-bar that completes the transformer. From Model 40 Functional Units.
Once the stack was complete, an I-bar was placed on top of each U to close the transformer core. A sense line (the reddish wiring below) was wrapped many times around each I-bar to detect the output signal. Each sense line was connected to a sense amplifier that detected the output signal, to produce the 60-bit output. (The I-bars and sense lines are missing from the TROS module I have but are visible in the module below.)
The sense windings are wrapped around the I-bars and connected to pins. The I-bars at the bottom are removed, showing the tops of the transformer U-pieces sticking up through the Mylar tapes. This TROS module is in the Computer History Museum.
The Mylar tapes were programmed by punching holes through wires to break the undesired wiring paths. The photo below shows a closeup of one of the tapes, showing the wiring printed on the tape, the large square holes for the transformer legs, and the small round holes punched through the word line wiring. The diagram on the right illustrates the wiring path resulting from the hole pattern. Each tape has two word lines (indicated in red and green) that go either through or around each transformer (gray rectangle).
Closeup of a TROS tape. The diagram on the right illustrates how the two traces (red and green) go through or around the transformers (gray rectangles), based on the holes punched in the tape.
To read one of the 256 words, one word line (wire loop) on one particular Mylar tape received a current pulse. The straightforward implementation would use 256 pulse drivers, with one selected by the address bits, but this much hardware would be expensive. Instead, the TROS module is driven by a "matrix" approach. The 256 word lines are wired logically into a 16×16 matrix. The address is split in half, and each half is decoded to select one of 16 lines. The word line that is selected on both ends line will receive a current pulse and be activated.2
Each Mylar tape is plugged into a diode board. Note the "2020" on the left, indicating that this module is from a System/360 Model 20.
Each Mylar tape is connected to one of two diode boards, resulting in hundreds of connections (above). (These diodes prevent the matrixed signals from all shorting together.) The diodes are inside the square aluminum modules below. The IBM System/360 didn't use integrated circuits, but instead used SLT modules, hybrid modules containing tiny semiconductors and thick film resistors. The SLT modules below each contain 8 diodes.
This closeup of the diode board shows the square metal SLT modules labeled 361485. Each one contains 8 diodes. The Mylar tape connections are at the top and bottom, while the "fin" in the middle is the wiring from the TROS module to the rest of the computer.
The TROS module I have was used on the low-end System/360 Model 20 computer, according to the label on it. The Model 20 was a slow, stripped-down system, lacking the full System/360 instruction set. Even so, its low cost ($1280 per month) made it the most popular System/360 model. The Model 20 contained 8 TROS modules, holding 6144 micro-instructions (3 micro-instructions per 60-bit word).3 These modules are visible on the left side of the computer below, mounted vertically. Note that the TROS modules take up a lot of space inside the computer.
IBM System/360 Model 20. TROS modules are on the left side. Photo from Ben Franske, CC BY 2.5.
In case you're wondering what the Model 20 microcode looks like, a sample is below. The microcode itself (in hex) is highlighted in blue, with the mnemonic expansion in green. Comments are on the right. The Model 20's microcode is much simpler than the horizontal microcode in larger System/360 systems.4
Microcode from the System 360/20.
The micro-operations in the code are "Branch if Zero", "Add Immediate", "Branch if Plus", and "Branch if Minus", all acting on register R1.
From FEMDM vol 2.
Microcode from the System 360/20. The micro-operations in the code are "Branch if Zero", "Add Immediate", "Branch if Plus", and "Branch if Minus", all acting on register R1. From FEMDM vol 2.
Why microcode?
One of the hardest parts of computer design is creating the control logic that tells each part of the processor what to do to carry out each instruction. In 1951, Maurice Wilkes came up with the idea of microcode: instead of building the control logic from complex logic gate circuitry, the control logic could be replaced with code (i.e. microcode) stored in a special memory called a control store. To execute an instruction, the computer internally executes several simpler micro-instructions, which are specified by the microcode. With microcode, building the processor's control logic becomes a programming task instead of a logic design task.
However, in the 1950s, storage technologies weren't fast and inexpensive enough to make microcode practical. It wasn't until the IBM System/360 (1964) that commercial computers made significant use of microcode. Microcode played a key role in the success of the System/360, helping IBM produce a line of computers with the same instruction set architecture but widely different implementations. Microcode also simplified backward compatibility, helping the System/360 support instruction sets of older IBM systems.5
IBM's various read-only storage techniques
IBM used several different read-only storage techniques to store microcode, for a combination of political and technical reasons. TROS was developed at IBM's Hursley site in England. This site started working on microcode because transistors were very expensive in England in the 1950s, and microcode could reduce the number of transistors required. Hursley developed a TROS for the SCAMP6 computer. This was followed by the TROS I've described, used on the System/360 Model 20 and Model 40, as well as the IBM 2841 file control unit.
A competing type of read-only storage is CCROS (Capacitive Coupled Read-Only Storage), which used Mylar sheets that functioned as a matrix of capacitors. An interesting feature of CCROS is that the Mylar sheets had the same size as an IBM punch card so microcode could be programmed by punching holes in it with a standard keypunch. CCROS was developed at IBM's Endicott site. Because the System/360 Model 30 was developed there too, it used the locally-developed CCROS even though CCROS was slower and less reliable than TROS. Each CCROS card holds 12 60-bit words. The Model 30 had 42 CCROS boards, each holding 8 cards, for a total of 4032 60-bit words.
Detail of a CCROS sheet. It is programmed by punching holes in it with a keypunch.
The high-performance Models 50, 65 and 67 required a faster control store, so they used a third technology, BCROS (Balanced Capacitor Read-Only Storage). Like CCROS, BCROS read bits by sensing capacitance, but BCROS used two capacitors for each bit (the Balanced Capacitors), which helped reduce noise and increased speed. The Mylar sheets for BCROS were 20″×8½″, much larger than the TROS and CCROS sheets. The data in BCROS was etched into the copper wiring (below), rather than by punching holes. Each bit is represented by two squares: one connected to the upper wire and one connected to the lower wire (or vice versa), forming the balanced capacitors. Each sheet plane held 176 words of 100 bits, and the system used 16 sheets to provide 2816 words.
Closeup of a BCROS sheet from a System/360 Model 50.
Instead of using special technology to store microcode, the low-end Model 25 held microcode in a 16-kilobyte section of core memory called Control Storage. In this model, different microcode was loaded from a card deck or tape to switch operating modes between System/360 and emulation of the legacy IBM 1400 series.
An important feature of these storage technologies is that the microcode could be easily updated at customer sites, by swapping the Mylar sheets (or card deck) holding the microcode. Many system bugs could be fixed inexpensively by changing the microcode. (In comparison, an "engineering change" on the older IBM 1401 typically required the engineer to modify wiring on the backplane, much more time-consuming and error-prone.) Microcode could also be upgraded if the customer purchased a new feature.
Comparison with core rope
TROS has some similarities with the core rope storage used by the Apollo Guidance Computer (AGC) to store programs, since both stored read-only data in the pattern of wires through cores. The tradeoffs were different between core rope and TROS. The AGC's core ropes were much more dense than TROS, an important feature for space flight. However, TROS could be easily changed by replacing the plastic tapes, while modifying a core rope required an expensive 8-week manufacturing process to wire up a new module.
Detail of core rope memory wiring from an early (Block I) Apollo Guidance Computer. Photo from Raytheon.
TROS and core rope are structurally the opposite, reversing the roles of word (address) lines and sense lines. TROS data depended on which word lines went through or around the transformer, while core rope data depended on which sense lines went through or around a core. To read a word in the AGC, one core was activated, while in TROS all of the transformers were (potentially) activated. Each transformer in TROS had one sense line and was associated with one output bit. In contrast, each core in the AGC's core rope had 192 sense lines and was associated with 12 words. (I've written more on core rope here).
TROS and other read-only storage technologies were a key ingredient in the overwhelming success of the IBM System/360 because they made microcode practical. However, the arrival of cheap semiconductor ROMs in the 1970s obsoleted complex storage technologies such as TROS. Nowadays, most microprocessors still use microcode, but it's stored in ROM inside the chip instead of in sheets of Mylar. Microcode can now be patched by downloading a file, rather than replacing Mylar sheets inside the computer.7
The TROS module, showing the diode boards and the stack of 128 Mylar tapes.
Notes and References
  1. The IBM System/360 was introduced in 1964. The date on this specific TROS module is May 27, 1970. ↩
  2. The diagram below illustrates how the matrix selection and diodes work. This diagram has been simplified to 2 drivers, 4 gates, and 8 word lines; the real system has 16 drivers, 16 gates, and 256 word lines. (What IBM calls a "gate" here is not a logic gate, but a current sink forming the other end of the circuit.) By energizing a particular driver and gate pair, a word line is selected. For instance, if driver 1 and gate 3 are energized, word line 3 is selected, as shown in red. Note that without the diodes, signals could go backward, incorrectly energizing multiple word lines.
    ↩Matrix selection of a word line. Energizing driver DR1 and gate G3 selects word line W3. Based on Model 40 Functional Units, p61.
  3. The Model 20 used 22-bit microcode words, so how did this work with 60-bit TROS? The trick was that some microcode words were truncated to 16 bits, so each TROS word held three microcode words: two 22-bit words, and one 16-bit word. In the Model 20's microcode, each word contained the address of the next microinstruction to execute. Since the truncated 16-bit word could only branch to a limited subset of next microinstructions. Thus, the microcode assembler had to carefully arrange the microcode so micro-instructions requiring a longer branch were stored in one of the longer 22-bit words. ↩
  4. A 90-bit micro-instruction in the Model 50 could perform half a dozen different functions in parallel. For example, each yellow box below is a single micro-instructions that is part of floating-point multiplications. Each line in the box is a separate action; the micro-instruction can control the emitter, adder, shifter, mover, and local storage in parallel. The point is that the Model 50 was faster (in part) because it had multiple functional units, and the microcode needed to be much more complicated to control them.
    Two micro-instructions (in yellow) in the System/360 Model 50. This is part of the microcode to handle exponent underflow and overflow during floating-point multiplication. The black lines show control flow. The text outside the box is comments. From Model 50 diagram QG702
  5. Most System/360 computers used microcode because it reduced cost, increased flexibility, and made development faster. IBM imposed a rule that System/360 computers had to be implemented in microcode unless there was a very good reason not to. The fastest models used hardwired control circuitry, though, to maximize performance. ↩
  6. Confusingly, IBM had two unrelated computers called SCAMP. The one using TROS is the Scientific Computer and Modulator Processor, a small computer developed at IBM Hursley for scientific applications, not the better-known prototype for the portable IBM 5100 (Special Computer APL Machine Portable). ↩
  7. Modern x86 chips have hardcoded microcode, along with some SRAM that holds microcode patches to fix processor flaws. The patches are downloaded into the processor by the BIOS (details) after each power-on. ↩
IBM, sonic delay lines, and the history of the 80×24 display
What explains the popularity of terminals with 80×24 and 80×25 displays? A recent blog post "80x25" motivated me to investigate this. The source of 80-column lines is clearly punch cards, as commonly claimed. But why 24 or 25 lines? There are many theories, but I found a simple answer: IBM, in particular its dominance of the terminal market. In 1971, IBM introduced a terminal with an 80×24 display (the 3270) and it soon became the best-selling terminal, forcing competing terminals to match its 80×24 size. The display for the IBM PC added one more line to its screen, making the 80×25 size standard in the PC world. The impact of these systems remains decades later: 80-character lines are still a standard, along with both 80×24 and 80×25 terminal windows.
In this blog post, I'll discuss this history in detail, including some other systems that played key roles. The CRT terminal market essentially started with the IBM 2260 Display Station in 1965, built from curious technologies such as sonic delay lines. This led to the popular IBM 3270 display and then widespread, inexpensive terminals such as the DEC VT100. In 1981, IBM released a microcomputer called the DataMaster. While the DataMaster is mostly forgotten, it strongly influenced the IBM PC, including the display. This post also studies reports on the terminal market from the 1970s and 1980s; these make it clear that market forces, not technological forces, led to the popularity of various display sizes.
Some theories about the 80×24 and 80×25 sizes
Arguments about terminal sizes go back decades,5 but the article 80x25 presented a detailed and interesting theory. To summarize, it argued that the 80×25 display was used because it was compatible with IBM's 80-column punch cards,1 fits nicely on a TV screen with a 4:3 aspect ratio, and just fit into 2K of RAM. This led to the 80×25 size on terminals such as the DEC VT100 terminal (1978). The VT100's massive popularity led to it becoming a standard, leading to the ubiquity of 80×25 terminals. At least that's the theory.
It's true that 80-column displays were motivated by punch cards4 and the VT100 became a standard,2 but the rest of this theory falls apart. The biggest problem with this theory is the VT100's display was 80×24, not 80×25.3 In addition, the VT100 used extra bytes of storage for each line, so the display memory did not fit into 2K. Finally, up until the 1980s, most displays were 80×24, not 80×25.
The DEC VT100 terminal had an 80×24 display. Over a million of them were sold. Photo from Jason Scott, (CC BY-SA 4.0).
Other theories have been expressed on Software Engineering StackExchange and Retrocomputing StackExchange, arguing that 80×24 terminals resulted from technical reasons such as TV scan rates, aspect ratios, memory sizes, typography, the history of typewriters, and so forth. There is a fundamental problem with theories that 80×24 is an inevitable consequence of technology, though: terminals in the mid-1970s had dozens of diverse screen sizes such as 31×11, 42×24, 50×20, 52×48, 81×38, 100×50, and 133×64.11 This makes it clear that technological limitations didn't force terminals into a particular size. To the contrary, as technology improved, most of these sizes disappeared and terminals were largely 80×24 by the early 1980s. This illustrates that standardization was the key factor, not the technology.
I'll briefly summarize why technical factors don't have much impact on the terminal size. Although US televisions used 525 scan lines and 60 Hz refresh,9 40% of terminals used other values.6 The display frequency and bandwidth didn't motivate a particular display size because terminals generated characters with a wide variety of matrix sizes.8 Although memory cost was significant, DRAM chip sizes quadrupled every three years, making memory only a temporary constraint. The screen's aspect ratio wasn't a big factor because the text's aspect ratio often didn't match the screen's ratio.7 Of course technology had some influence, but it didn't stop early manufacturers from creating terminal sizes ranging from 32×8 to 133×64.
The rise of CRT terminals
At this point, a bit of history of CRT terminals will help.11 Many readers will be familiar with ASCII terminals, such as stand-alone terminals like the DEC VT100, serial terminal connections via a PC, or the serial port on boards such as the Arduino. This type of terminal has its roots in teleprinters, electro-mechanical keyboard/printers that date back to the early 1900s. The best-known teleprinter is the Teletype, popular in newsrooms as well as computer systems in the 1970s. (The Linux device /dev/tty is named after the Teletype.) Teletypes typically printed 72-character lines on a roll of paper.10
A Teletype ASR33 communicated in ASCII and printed 72 characters per line. Hundreds of thousands of these were produced from 1963 to 1981. The punched tape reader and punch is on the left. Photo from Arnold Reinhold, (CC BY-SA 3.0).
In the 1970s, replacing teleprinters with CRT terminals was a large and profitable market. AT&T introduced the Teletype Model 40 in 1973, a CRT terminal with an 80×24 display.12 Many other companies introduced competing CRT terminals, and "Teletype-compatible" became a market segment. By 198111 these terminals were being used in many roles besides replacing teleprinters and the name shifted to "ASCII terminals". By 1985, CRT terminals were a huge success with 10 million terminals installed in the US.
The IBM 3270 terminal, specifically the newer 3278 model. From IBM 3270 Brochure (1977).
But there's a parallel world of mainframe terminals, a world that may be unfamiliar to many readers. In 1965, IBM introduced the IBM 2260 Display Terminal, which placed IBM's "stamp of approval" on the CRT terminal, which had previously been "somewhat of a novelty."6 This terminal dominated the market until IBM replaced it with the cheaper and more advanced IBM 3270 terminal in 1971. Unlike asynchronous ASCII terminals that transmitted individual keystrokes, these terminals were block oriented, efficiently exchanging large blocks of characters with a mainframe. The 3270 terminal was fairly "intelligent": a 3270 user could fill in labeled fields on the screen, and then transmit all the data at once by pressing the "Enter" key. (This is why modern keyboards often still have the "Enter" key.) Sending a block of data was more efficient than sending each keystroke to the computer, and allowed mainframes to support hundreds of terminals. In the next sections, I'll discuss the 2260 and 3270 terminals in detail.
The chart below6 shows how the terminal market looked in 1974. The market was ruled by IBM's 3270 terminal, which had obsoleted IBM's 2260 terminal by this point. With 50% of the market, IBM essentially defined the characteristics of a CRT terminal. Teleprinter replacement was a large and influential market; the Teletype Model 40 was small but growing in importance. Although DEC would soon be a major player, it was in the small "Independent Systems" slice at this point.
In 1974, IBM dominated the terminal market; 50% of the terminals sold were IBM terminals (or compatibles). From Alphanumeric and Graphic CRT Terminals.
The IBM 2260 video display terminal
The IBM 2260 was introduced in 1965 and was one of the first video display terminals.14 It filled three roles: remote data entry (in place of punching cards), inquiry (e.g. looking up records in a database), and as a system console. This compact terminal weighed 45 pounds and was sized to fit on a standard office typewriter stand. Note the thickness of the keyboard; it reused the complex keyboard mechanism of the IBM keypunch.13
IBM 2260 Display Station. Photo from IBM via Frank da Cruz.
You might wonder how IBM could produce such a compact terminal with 1965 technology. The trick was that the terminal held just the keyboard and CRT display; all the control logic, character generation, storage, and interfacing was in a massive 1000 pound cabinet (below).15 This cabinet contained the circuitry to handle up to 24 display terminals. It generated the pixels for these terminals and send video signals to the terminals, which could be up to 2000 feet away.
The IBM 2848 Display Control could drive up to 24 display terminals.
The cabinet was 5 feet wide and weighed 1000 pounds.
The IBM 2848 Display Control could drive up to 24 display terminals. The cabinet was 5 feet wide and weighed 1000 pounds.
One of the most interesting features of the 2260 is the sonic delay lines used for pixel storage. Bits were stored as sound pulses sent into a nickel wire, about 50 feet long. The pulses traveled through the wire and came out the other end exactly 5.5545 milliseconds later. By sending a pulse (or not sending a pulse for a 0) every 500 nanoseconds, the wire held 11,008 bits. A pair of wires created a buffer that held the pixels for 480 characters.16
Sonic delay line module from the IBM 2260 display. This module contained about 50 feet of coiled nickel wire. Image from 2260 Field Engineering Theory of Operation Manual.
The sonic delay line had several problems. First, you had to constantly refresh the data: as bits came out one end of the wire, you had to feed them back in the other end. Second, the delay line was not random access: if you wanted to update a character, you needed to wait several milliseconds for those bits to circulate. Third, the delay line was sensitive to vibration; Wikipedia says that heavy footsteps could mess up the screen. Fourth, the delay line speed was sensitive to temperature changes; it needed to warm up for two hours in a temperature-controlled cabinet before use. With all these disadvantages, you might wonder why sonic delay lines were used. The main reason was they were much cheaper than core memory. The serial nature of a delay line was also a good match to the serial nature of a raster-scan display.
The coiled nickel wire inside a sonic delay has transducers at both ends (center and bottom left, with twisted wiring attached).
To adjust the delay, the threaded rod (bottom left) moves the transducer's position along the wire. The metal boxes on the ends of the wires are
dampers to prevent reflections. Photo courtesy of Alan Parker.
The coiled nickel wire inside a sonic delay has transducers at both ends (center and bottom left, with twisted wiring attached). To adjust the delay, the threaded rod (bottom left) moves the transducer's position along the wire. The metal boxes on the ends of the wires are dampers to prevent reflections. Photo courtesy of Alan Parker.
The image below shows the screen of the 2260 Model 2, with 12 lines of 40 characters. (The Model 1 had 6 lines of 40 characters and the Model 3 had 12 lines of 80 characters.) Notice that the lines are double-spaced; this is because the control unit actually generated 24 lines of text but alternating lines went to two different terminals.20 This is a very strange approach, but it split the high cost of the control hardware across two terminals.19 Another strange characteristic was that the 2260's scan lines were vertical, unlike the horizontal scan lines in almost every video display and television.21
IBM 2260 display showing 12 lines of 40 characters. Image from 2260 Operator Manual.
Each character was represented in 6-bit EBCDIC, giving a character set of 64 characters (no lower-case). 18 The delay lines stored the pixels to be displayed, but they also stored the EBCDIC code for each character. The trick here is the blank column of pixels between each character for horizontal spacing between characters. The system used this column to store the BCD character value but blanked the display during this column so the BCD value didn't show up as pixels on the screen. This allowed the 6-bit character value to be stored essentially for free.
The relevant question is why did the 2260 have a display with 12 lines of 80 characters?2324 The 80-character width allowed the terminals to take the place of 80-column punch cards for data entry. (In the 40-character models, a card would be split across two lines.) As for the 12 lines, that appears to be what the delay lines could support without flicker.22
The IBM 2260 was a big success, and led to the popularity of the CRT terminal. The impact of the IBM 2260 terminal is shown by a 1974 report on terminals; about 50 terminals were listed as compatible with the IBM 2260. The IBM 2260 didn't have an 80×24 display (although it generated 80×24 internally), but its 40×12 and 80×12 displays made 80×24 the next step for IBM.
The IBM 3270 video display
In 1971, IBM released the IBM 3270 video display system, which proceeded to dominate the market for CRT terminals.26 This terminal supported a 40×12 display to provide a migration path from the 2260, but also supported a larger 80×24 display. The 3270 had more features than the 2260, such as protected fields on the screen, more efficient communication modes, and variable-intensity text. It was also significantly cheaper than the 2260, ensuring its popularity.25
The IBM 3270 terminal. The Selector Light Pen was used to select data fields, somewhat like a mouse. This terminal is a later model, the 3278; in the photo it is displaying 43 lines of 80 characters. From IBM 3270 Brochure (1977).
The technology in the 3270 was a generation more advanced than the 2260, replacing vacuum tubes and transistors with hybrid SLT modules, similar to integrated circuits. Instead of sonic delay lines, it used 480-bit MOS shift registers.27 The 40×12 model used one bank of shift registers to store 480 characters. In the larger model, four banks of shift registers (1920 characters) supported an 80×24 display. In other words, the 3270's storage was in 480-character blocks for compatibility with the 2260, and using four blocks resulted in the 80×24 display. (Unlike RAM chips, a shift register size didn't need to be a power of 2. While a RAM chip is arranged as a matrix, a shift register has a serpentine layout (below) and can be an arbitrary size.)
Die photo of the Intel 1405 shift register. This shift register was not used in the IBM 3270 but was used in other terminals such as the Datapoint 2200.
IBM provided extensive software support for the 3270 terminal.28 This had an important impact on the terminal market, since it forced other manufacturers to build compatible terminals if they wanted to compete. In particular, this made 3270-compatibility and the 80×24 display into a de facto standard. In 1977, IBM introduced the 3278, an improved 3270 terminal that supported 12, 24, 32, or 43 lines of data. It also added a status line, called the "operator information area". The new 32- and 43-line sizes didn't really catch on, but the status line became a common feature on competing terminals.
Looking at industry reports61132 shows the popularity of various terminal sizes from the 1970s to the 1990s. Although there were 80×25 displays in 1970 (if not earlier), the 80×24 display was much more common. The wide variety of terminal sizes in 1974 diminished over time, with the market converging on 80×24. By 1979, the DEC VT100 (with its 80×24 display) was the most popular ASCII terminal with over 1 million sold. Terminals started supporting 132×24 for compatibility with 132-character line printers,29 especially as larger 15" monitors became more affordable, but 80×24 remained the most popular size. Even by 1991, 80×25 remained relatively uncommon.
The IBM PC and the popularity of 80×25
Given the historical popularity of 80×24 terminals, why do so many modern systems use 80×25 windows? That's also due to IBM: the 80×25 display became popular with the introduction of the IBM PC in 1981. The PC's default display card (MDA) provided 80×25 monochrome text while the CGA card provided 40×25 and 80×25 in color. This became the default size of a Windows console, as well as the typical size for PC-based terminal windows.
The IBM PC with an 80×25 display generated by the MDA (Monochrome Display Adapter) card. Photo from Boffy b (CC BY-SA 3.0).
Other popular computers at the time used 24 lines, such as the Osborne 1 and Apple II, so I was curious why the IBM PC used 25 lines. To find out, I talked to Dr. Dave Bradley and Prof. Mark Dean, two of the original IBM PC engineers. They explained that the IBM PC was a follow-on to the rather obscure IBM DataMaster office computer,30 and many of the IBM PC design choices followed the DataMaster microcomputer. The IBM PC kept the DataMaster's keyboard, but detached from the main unit. Both systems used BASIC, but the decision to get the PC's BASIC interpreter from the tiny company Microsoft would change both companies more than anyone could imagine. Both systems went with an Intel processor, an 8-bit 8085 in the DataMaster and the 16-bit 8088 in the IBM PC. They also used the same interrupt controller, parallel port, and timer chips, and almost the same DMA controller. The PC's 62-pin expansion bus was almost identical to DataMaster's.
The IBM DataMaster System/23 was a microcomputer announced in 1981 just a month before the IBM PC.
The drawing below is part of an early design plan for the IBM PC. In particular, the IBM PC was going to use the 80×24 display of the DataMaster (codenamed LOMA), as well as 40×16 and 60×16 more suitable for televisions. The drawings also show color graphics with 280×192 pixels, the same resolution as the Apple II. But the IBM PC ended up not quite matching this plan.
Detail from an early (August 25, 1980) design plan for the IBM PC. "LOMA" is the code name for the IBM DataMaster. "18 kHz" is the 18.432 kHz horizontal scan frequency used by the MDA card, providing more resolution than the 15.750 kHz used by NTSC televisions. Scan courtesy of Dr. Dave Bradley.
The designers of the IBM PC managed to squeeze a few more pixels onto the display to get 320×200 pixels. When using an 8×8 character matrix, the updated graphics mode supported 40×25 text, while the double-resolution graphics mode with 640×200 pixels supported 80×25 text. The monochrome graphics card (MDA) matched this 80×25 size. In other words, the IBM PC ended up using 80×25 text because the display provided enough pixels, and it provided differentiation from other systems, but there wasn't an overriding motivation. In particular, the designers of the PC weren't constrained by compatibility with other IBM systems.31
To summarize, many theories have been proposed giving technical reasons why 80×24 (or 80×25) is the natural size for a display. I think the wide variety of display sizes in the early 1970s proves this technological motivation is mostly wrong. Instead, display sizes converged on what IBM produced, first with the punch card, then the IBM 2260 terminal, the IBM 3270, and finally the IBM PC. The 72-column Teletype had some influence on terminal sizes at first, but this size was also swept away by IBM compatibility. The result is the current situation with an uneasy split between 80×24 and 80×25 standards.
Thanks to Dr. Dave Bradley, Prof. Mark Dean, and IBM engineer Iggy Menendez for information. I announce my latest blog posts on Twitter, so follow me @kenshirriff for future articles. I also have an RSS feed.
  1. Punch cards have a longer history than you might think. The standard 80-column IBM punch card was introduced in 1928, improving on punch cards used for the 1890 census. Before the modern computer, punch cards were processed with electromechanical sorters and accounting machines. The punch card remained a keystone of data processing until the 1970s, and its impact still remains.
    An IBM punch card holds 80 characters, printed along the top. The hole pattern in each column encodes the character.
  2. By 1986, the DEC VT100 was "an acknowledged standard in the terminal industry" and "the most popular ASCII terminal ever produced, with 1,000,000 units sold since its introduction in 1978." ↩
  3. For information on the internals of the VT100 see the Technical Manual. The VT100 had 3K of memory, of which about 2.3K was used for the screen while the 8080 microprocessor used the remainder. Each line was stored in memory with 3 additional bytes on the end, used as pointers for scrolling. ↩
  4. It should be clear that IBM's 80-column punch cards were the motivation for 80-column displays, but I wanted to find contemporary sources to confirm that. One example is All About CRT Display Terminals (1974, page 11) stating that terminals with an 80-column line gave compatibility with punched cards while the 72-column line provided compatibility with Teletypes. Also see Big Screen, 132-Column Units Setting Trend, Computerworld, Oct 26, 1981. Although the article focuses on 132-column terminals to replace printers, the article also describes how earlier terminals had an 80-column format like the punch cards they replaced. ↩
  5. Controversy over the reason for 80×24 displays goes way back. An editorial in Infoworld (Nov 2, 1981) argued that microcomputers shouldn't be locked into the "arbitrary" 80×24 size. This led to angry letters to the editor in Infoworld, Nov 30, 1981, arguing that 80×24 wasn't arbitrary. Writers explained that 80-columns were motivated by punch cards, 24 (or sometimes 25) lines were motivated by tradeoffs in CRT technology, and memory size didn't have much to do with it. ↩
  6. A detailed source of information on terminals is a 1975 report Alphanumeric and Graphic CRT Terminals. ↩
  7. The CRT's aspect ratio matters less than people think. The first reason is that even on a CRT with a 4:3 aspect ratio, many terminals displayed text with a very different aspect ratio by leaving part of the screen blank. Although most terminals used a CRT with the standard 4:3 aspect ratio, the actual text could have a very different aspect ratio. The second reason is that terminals could use a custom CRT size if they wanted. For instance, the Datapoint 2200 had an unusually wide CRT, designed to match the shape of a punch card. (Reference: Datapoint: The lost story of the Texans who invented the personal computer revolution chapter 4.) The popular Teletype Model 40 also had an unusually wide CRT, with an aspect ratio over 2:1 (photos), which was used for an 80×24 display. ↩
  8. A raster-scan terminal makes each character out of a matrix of dots. In 1975, a 5×7 or 7×9 matrix was most common.6 (The matrix was often padded with space between characters. For instance, the Apple II used a 5x7 dot matrix padded to a 7×8 field.) Some systems (such as IBM's CGA card) used an 8×8 matrix without padding to supporting graphical characters that touched. Other systems used a much larger character matrix; the IBM Datamaster used 7×9 characters in a 10×14 field, while the Quotron 800 had a 16×20 matrix. The point is that 80×24 terminals can require a wildly varying number of pixels, depending on the matrix selected. This is the flaw in the argument that the bandwidth and scanlines of a display motivated 80×24 terminals; you get a completely different answer depending on the matrix size you pick. ↩
  9. Home computers in the 1980s often used standard NTSC televisions as displays, so they had to deal with more constraints that terminals. As a result, they often had 40- or 64-character lines, rather than 80, as shown by the Wikipedia list. Also see a Retrocomputing StackExchange discussion. ↩
  10. One Retrocomputing StackExchange answer claims that terminals with 72-character lines show "the struggle for 80 characters", with 72-character terminals falling short of the 80-character goal. However, 72-character lines were a deliberate choice to capture the lucrative Teletype market; teleprinters such as the Teletype Model 33 printed 72-character lines. (The model number of the Datapoint 3300 (1969), for instance, reflects the Teletype Model 33.) ↩
  11. For an extremely detailed look at the terminal industry from 1974 to 1991, see the Datapro reports on Bitsavers. These reports discuss the overall market, as well as thoroughly describing every terminal being marketed. ↩
  12. AT&T's Teletype Model 40 is mostly forgotten now, but it had a significant impact at the time. AT&T combined the Model 40 with a new, faster communications network called "Dataspeed 40", raising fears that AT&T would monopolize data communications. It is said that this "spread waves of apprehension that penetrated the very foundation of the communications terminal industry." AT&T targeted IBM's 3270 terminals with the Model 40/4 (which probably explains Model 40's 80×24 display). Complex antitrust litigation against AT&T resulted, which I think blunted the long-term impact of the Model 40. ↩
  13. The IBM 2260 terminal reused the keyboard of the IBM 26 keypunch (1949). To convert a keypress into a hole pattern, the keypunch keyboard used a complex system of pull-bars, permutation bars (which encode key values in metal tabs), bails, contacts, interlock disks, and restoring electromagnet. Each key triggers 12 contacts; in the keypunch these controlled the 12 holes in each card column, while in the terminal these encode two 6-bit codes, one for shifted and one for non-shifted. This mechanism was much more complex than a "modern" keyboard but it had the advantage of generating key codes without requiring any electronics. (I've written about keypunch internals before.) ↩
  14. Vector graphics displays predate video terminals by many years, used on systems such as Whirlwind (1951) and SAGE (1958) and later the IBM 2250 Graphics Display Unit (1964). These systems drew arbitrary lines on the screen, rather than pixels. Although these systems could display characters (drawn from line segments), they were very expensive and usually used for graphics, not as character-based terminals.  ↩
  15. The CRT/keyboard unit was called the IBM 2260 Display Station, while the large cabinet with the circuitry was called the IBM 2848 Display Control. People often referred to the complete system as the 2260; I'll follow this usage. ↩
  16. I'll explain more about the delay line buffers in this footnote. A delay line provided a bit every 500 nanoseconds. Two delay lines were interleaved in a buffer to provide bits twice as fast: every 250 nanoseconds. Data was formatted as 256 "slots", one per vertical scan line. (These slots were purely conceptual since the delay line provided an undifferentiated stream of bits.) 240 slots held data, while 16 were blank for horizontal retrace time. Each slot held 86 bits: 7 bits for 12 rows of characters, along with two parity bits. (Since each scan line was split across two displays, the slot corresponded to 6 characters on the even display and 6 on the odd display.) Six slots made up a vertical line of characters: one slot holding the "BCD" character value, and five slots holding pixels. Thus, each buffer holds data for 480 characters and supported two 40×6 displays. Two buffers supported a pair of 40×12 displays and four buffers supported a pair of 80×12 displays. Details are in the 2260 Field Engineering Theory of Operation Manual, page 2-14. ↩
  17. A delay line can't be paused—the bits keep flowing, even during vertical and horizontal refresh times. The problem is that you can't display anything during refresh, since the electron beam is swinging back to the start, so what do you do with the pixels the display line provides during that time. The 2260 used two solutions. Horizontal refresh was straightforward, "wasting" delay line bits during the horizontal refresh time. Specifically, a pair of buffers held 512 scan lines; 480 were used for character data while 32 were unusable because horizontal refresh happened while they were being read.
    The interaction between the delay lines and vertical refresh is somewhat complicated. The vertical refresh time was designed to be exactly the same as the 5.5545ms time it took a buffer to fully circulate, while the time to display a vertical scan line was exactly twice this time. Two buffers were interleaved to provide the vertical scan lines. During the first time interval, the first buffer provided pixels for the top half of the line. During the second time interval, the second buffer provided pixels for the bottom half of the line. The third time interval was used for vertical refresh. This pattern continued until the end of the buffers, so every third slot in a buffer was displayed while the "unused" pixels were recirculated. This process was repeated three times, offsetting the start point in the buffer, so the buffers were displayed entirely. ↩
  18. Another curious feature of the IBM 2260 display is how it converted the 6-bit character code into the 5×7 block of pixels representing the character. It used a special core memory plane that only had cores for 1 bits and omitted cores for 0 bits, so it acted as a read-only memory. The result is you could actually see the characters in core plane, as illustrated below. The core plane holds nine 7-bit words for each of the 64 characters: the first five words held the pixel block, while the four other words were a lookup table to convert the EBCDIC character code (2848 code) to or from ASCII or a tilt-shift code used to control the Selectric-like printer (Model 1053).
    Part of the character generation core plane, showing the segment for the character 'A'.
The diagonal lines indicate ferrite cores; I've colored the cores storing the character image.
The core plane was a 72×56 grid in total representing 64 characters.
Image based on 2260 Field Engineering Theory of Operation Manual p2-82.
    Part of the character generation core plane, showing the segment for the character 'A'. The diagonal lines indicate ferrite cores; I've colored the cores storing the character image. The core plane was a 72×56 grid in total representing 64 characters. Image based on 2260 Field Engineering Theory of Operation Manual p2-82.
  19. IBM apparently liked the idea of splitting display hardware between two users, because they did that with the IBM 3742 Dual Data Station (1973). This system let two operators enter data onto 8" floppy disks. The bizarre part is that it had a single vertically-mounted CRT display. The small black box in the middle of the desk is a pair of mirrors that showed half the screen to each operator. The result was a very squat display with just three lines of 40 characters, enough for a status line and 80 characters of data.
    The IBM 3742 Dual Data Station allowed two operators to type data onto floppy disks. Image from IBM 3740 System Summary.
  20. The lines of text in the screenshot appear closer together than double-spaced, even though they are double-spaced. The reason is that the dots on the screen are a bit larger than one pixel, so they encroach into the space between the lines. In other words, the display alternates 7 lines of character pixels and 7 blank lines, but it looks more like 9 lines of character pixels and 5 blank lines. ↩
  21. Televisions and CRT displays normally use a raster scan, scanning the electron beam across the screen in horizontal scan lines, making a series of lines from top-to-bottom. The 2260, on the other hand, has highly-unusual vertical scan lines; the scan lines are top-to-bottom, and the series of lines progressed left-to-right across the screen. I haven't been able to determine any reason why the 2260 has vertical scanlines. I assume it made the timing work out better somehow.  ↩
  22. Here are my calculations on the maximum number of lines that could be displayed by the 2260. A 250 nanosecond pixel rate and 30 Hertz refresh give a maximum of 133,333 pixels that can be displayed on the screen. If each character is 6×7 pixels and there are 80 characters per line, 39.7 lines could be on the screen. Vertical refresh takes 1/3 of the time because of interaction with the delay lines,17 dropping this to 26.5 lines. Because the 2260 splits pixels across two displays, that yields at most 13.25 lines on the display, ignoring horizontal refresh. Therefore, 12 lines of text are about what the hardware could support. (I should point out that it's possible they decided on 12 lines first and selected the other design characteristics to fit this.) Note that the next reasonable line size would be 16 lines. The low-end model displayed 6 lines of 40 characters (i.e. 3 punch cards), so the next step for it would be 8 lines of 40 characters (four punch cards). Since the high-end model uses four buffers, that would yield 16 lines. The point is that it would have been a large jump to go beyond 12 lines. ↩
  23. The 2260 came in three models. Model 1 displayed 6 lines of 40 characters. Model 2 displayed 12 lines of 40 characters. Model 3 displayed 12 lines of 80 characters. The main difference in implementation was that they used 1, 2, and 4 buffers respectively. The 40-character models refreshed at 60 Hz rather than 30 Hz, since they had half the (vertical) scanlines. ↩
  24. The aspect ratio of the IBM 2260's text was very different from the screen's aspect ratio. With the bezel, the screen's useful display area is 9.5 by 5.7 inches (5:3 ratio). Note that the aspect ratio of the text was very different from a standard 4:3 ratio. The 40×6 display format is 6.5 by 2.25 inches (almost 3:1 ratio). The 40×12 display format is 6.5 by 4.5 inches (a bit over 4:3 ratio). The 80×12 display format is 9 by 3 inches (3:1 ratio). Information on the 2260's screen size is in the FE Manual chapter 2. ↩
  25. The 1974 Datapro report gives the price for the IBM 2260 system as $1270 to $2140 for the display unit and $15,715 to $86,365 for the controller. The IBM 3270 in comparison was $4,000 to $7,435 for the display unit (3277) and $6,500 to $15,725 for the controller. Note that compared to the 2260, the 3270 moved much of the complexity from the controller to the display unit, which is reflected in the prices. ↩
  26. The IBM 3270 was a line of terminals. Like the 2260, it consisted of a 3271 or 3272 Control Unit (interesting video here) along with the terminals (3275 or 3277 Display Stations). These could display 40×12 or 80×24. For simplicity, I'll refer to the whole system as the 3270. Over the years, IBM introduced more models in the 3270 line, including color and graphics terminals, supporting lower case as well as display sizes such as 80×32, 80×43, and 132×27. The 3270 PC (1983) was an enhanced IBM PC that acted as a 3270 terminal. However, I'm going to focus on the original 3270 terminals, since those had the most influence. ↩
  27. A 480-bit shift register might seem like a strange size, since it's not a power of two. However, since shift registers don't have address bits, they can be arbitrary sizes. For instance, Collins made dual 66-bit shift registers, to support 64-bit data plus 2 parity bits. Fairchild made 480-bit shift registers for CRT displays. 500-bit shift registers were built "to operate in equipment where storage lengths in 100 bit multiples are required." Texas Instruments built dynamic bipolar shift registers in 253-bit, 349-bit, and 501-bit sizes which were useful for Digital Differential Analyzers. The point is that shift registers can be built in arbitrary sizes, so there is no need to use a power of two.
    Schematic symbol for the 480-bit shift register in the 3270. Inputs are data and the two-phase clock. "SPEC" indicates a special circuit. From the ALD, page MP151.
    The 3270 used banks of ten 480-bit shift registers to store 480 10-bit data words (9 bits and parity), unlike the earlier 2260 delay lines, which stored pixels. ↩
  28. Software support for the 3270 included DIDOCS (Device Independent Display Operator Console Support), using the 3270 as a mainframe system console; VIDEO/370 (Visual Data Entry Online), a program that allowed customers to design forms for data entry; DATA/360, a program that emulated an IBM 29 card punch, but provided editing and validation; IMS (Information Management System); (CICS) Customer Information Control System, which allowed interaction with a database; IQF (Interactive Query Facility), another database system; and TSO (Time Sharing Option). ↩
  29. The 132-column width for terminals was motivated by the ubiquity of IBM's 132-column printers. ↩
  30. The DataMaster's influence on the IBM PC is described in two articles by Dr. Dave Bradley: The creation of the IBM PC in Byte, Sept. 1990; and A personal history of the IBM PC, IEEE Computer, Aug 2011 (paywalled). The Wikipedia article DataMaster System/23 also provides information. ↩
  31. Dr. Bradley explained that the designers of the IBM PC weren't concerned with compatibility with other systems. For instance, you might expect the IBM PC to be compatible with the 3270 terminal. However, the IBM PC's keyboard had 10 function keys while the IBM 3270 terminal had 12. This incompatibility was finally fixed with the IBM PS/2 keyboard (1987). ↩
  32. To confirm the popularity of 80×24 terminals versus 80×25 terminals, I took a look at the GNU termcap file. I counted and found there were over 5 times as many 24-line terminals as 25-line terminals, and the 25-line terminals were mostly PC-based. 80-column terminals were over 5 times as popular as 132-column terminals, the runner-up. ↩
