How "special register groups" invaded computer dictionaries for decades
Half a century ago, the puzzling phrase "special register groups" started showing up in definitions of "CPU", and it is still there. In this blog post, I uncover how special register groups went from an obscure feature in the Honeywell 800 mainframe to appearing in the Washington Post.
While researching old computers, I found a strange definition of "Central Processing Unit" that keeps appearing in different sources. From a book reprinted in 2017:1
"Central Processor Unit (CPU)—Part of a computer system which contains the main storage, arithmetic unit and special register groups. It performs arithmetic operations, controls instruction processing and provides timing signals."
At first glance, this definition seems okay, but a few moments thought reveals some problems. Storage is not part of the CPU. But more puzzling, what are special register groups? A CPU has registers, but "special register groups" is not a normal phrase.
It turns out that this definition has been used extensively for over half a century, even though it doesn't make sense, copied and modified from one source to another. Special register groups were a feature in the Honeywell 800 mainframe computer, introduced in 1959. Although this computer is long-forgotten2, its impact inexplicably remains in many glossaries. The Honeywell 800 allowed eight programs to run on a single processor, switching between programs after every instruction.3 To support this, each program had a "special register group" in hardware, its own separate group of 32 registers (program counter, general-purpose registers, index registers, etc.).
Honeywell 800 computer. The Central Processing Unit (containing special register groups) is in cabinets 6 feet high and 18 feet wide along the wall. The card reader and printer are in the center of the room. A typical system rented for $25,000 a month. Photo from BRL report, 1961 courtesy of Ed Thelen.
Another important thing to note about that era is the central processing unit was a large physical box, also known as the "main frame". (A mainframe was not a type of computer yet.) Thus, given the characteristics of the Honeywell 800, the definition of CPU in Honeywell's glossary4 made total sense.5 Unfortunately, this definition doesn't make sense when used for computers in general, since they lack special register groups.
Honeywell's definition of main frame: "FRAME, MAIN, (I) the central processor of the computer
system. It contains the main storage, arithmetic unit and
special register groups. Synonymous with (CPU) and
(central processing unit). (2) All that portion of a computer exclusive of the input, output, peripheral and in some
instances, storage units."
Honeywell's definition of main frame: "FRAME, MAIN, (I) the central processor of the computer system. It contains the main storage, arithmetic unit and special register groups. Synonymous with (CPU) and (central processing unit). (2) All that portion of a computer exclusive of the input, output, peripheral and in some instances, storage units."
This definition apparently started with the US Department of Agriculture's Glossary of ADP Terminology (1960): "MAIN FRAME - The central processor of the computer system. It contains the main memory, arithmetic unit and special register groups". The definition then spread through the government. The Bureau of the Budget published the Automatic Data Processing Glossary in 1962 "for use as an authoritative reference by all officials and employees of the executive branch of the Government" with the definition below. The Air Force's 1966 Guide for Auditing Automatic Data Processing Systems used a similar definition as did the 1966 Navy Training Course for Machine Accountant and 1968 Air Force manual Communications-Electronics Terminology.
Bureau of the Budget's 1962 definition: "frame, main, (1) the central processor of the computer system. It contains the main storage, arithmetic unit and special register groups. Synonymous with CPU and central processing unit. (2) All that portion of a computer exclusive of the input, output, peripheral and in some instances, storage units."
From there, the definition spread to dozens of books and dictionaries. The "special register groups" appeared in numerous computer glossaries such as the Glossary of Computing Terminology (1972), Computer Glossary for Medical and Health Sciences (1973) Computer Glossary for Engineers and Scientists (1973), Radio Shack's Dictionary of Electronics (1968, 1974-1975), and Computer Graphics Glossary (1983)
Radio Shack's New 1974-1975 Dictionary of Electronics contains the definition:
"central processing unit—Also called central processor. Part of a computer system which
contains the main storage, arithmetic unit, and special register groups. Performs arithmetic operations, controls instruction processing, and provides timing signals and other housekeeping operations."
Radio Shack's New 1974-1975 Dictionary of Electronics contains the definition: "central processing unit—Also called central processor. Part of a computer system which contains the main storage, arithmetic unit, and special register groups. Performs arithmetic operations, controls instruction processing, and provides timing signals and other housekeeping operations."
Computer manufacturers should know their systems don't have special register groups, but they still used the definition. For example, Sphere microcomputer (1976), Texas Instruments (1978), Cray (1984), Convergent Technologies (1987), and Tektronix (1989).
This definition persisted into the microcomputer age, even though storage was now clearly not part of the CPU and "special register groups" were decades in the past. A 1983 Beginner's Computer Glossary in MICRO magazine defined "CPU — Central Processing Unit. The central processor of the computer system, which contains the main storage, arithmetic unit, and special register groups." "Special register groups" also showed up in Microcomputer Dictionary (1981), and Understanding Microprocessors (1984),
Definitions with "special register groups" appeared in a dizzying array of books, such as Computer Technology in the Health Sciences (1974), College Typewriting (1975), Research Methods for Recreation and Leisure (1979), EPA's Design Automation Handbook for Automation of Activated Sludge Treatment Plants (1980), Patrick-Turner's Industrial Automation Dictionary (1996), Video Scrambling & Descrambling (1998), US Department of Transportation's Computerized Signal Systems (1979). and Traffic Control System Operations (2000).
In 1981, special register groups reached national newspapers in a Washington Post glossary: "Main-frame—central processor of computer system, containing main storage, arithmetic unit and special register groups." By 2006, even the National Fire Code6 included special register groups: "Computer. A programmable electronic device that contains a central processing unit(s), main storage, an arithmetic unit, and special register groups."
Special register groups are still being taught to the next generation of students. The following quiz question is from a 2017 book that teaches computer organization and programming:7
CPU of a computer system does not contain:
(a) Main storage
(b) Arithmetic unit
(c) Special register group
(d) None of the above
For some reason, a 1960 definition of "central processing unit" included "special register groups", an obscure feature from the Honeywell 800 mainframe. This definition was copied and changed for decades, even though it doesn't make sense. It appears that once something appears in an authoritative glossary, people will reuse it for decades, and obsolete terms may never die out.
"Computer operators working with tape-driven Honeywell 800 mainframe computer."
The operators in this photo from the 1960s are presumably taking advantage of the special register groups unique to the Honeywell 800 and 1800 computers.  Photo from National Library of Medicine.
"Computer operators working with tape-driven Honeywell 800 mainframe computer." The operators in this photo from the 1960s are presumably taking advantage of the special register groups unique to the Honeywell 800 and 1800 computers. Photo from National Library of Medicine.
Researching this phrase also shows how the meanings of computer terms shift greatly over time. In 1960, "main frame" and "CPU" were synonyms, but since then they have moved in opposite directions: "mainframe" is now a large computer system, while the "CPU" is usually a processor chip. (I plan to write much more about this.)
Notes and References
  1. Reference: Reliability Engineering for Nuclear and Other High Technology Systems, CRC Press, 2017, reprint of a book originally published in 1985. ↩
  2. I happen to be familiar with the Honeywell 800 and 1800 computers because I've been studying the Apollo Guidance Computer extensively. (The Honeywell 1800 was an improved version of the Honeywell 800.) The Honeywell 1800 was used to assemble programs for the Apollo Guidance Computer using an assembler called YUL. ↩
  3. The Honeywell 800's technique of switching programs on every instruction is rather unusual. Typical multi-tasking systems let a program run for several milliseconds before switching to another program to reduce the overhead of switching between programs. The Honeywell 800 Programmers Reference Manual explains the use of special register groups for multiprogramming. ↩
  4. Honeywell's Glossary of Data Processing and Communications Terms was published 1964-1966. Definitions in that book are largely based on the Bureau of the Budget's Automatic Data Processing Glossary. ↩
  5. The Oxford English Dictionary (1989) quoted the 1964 Honeywell definition. ↩
  6. Reference: NFPA's Illustrated Dictionary of Fire Service Terms, published by the National Fire Protection Association in 2006. The National Fire Codes (1995) had a somewhat similar definition, but for the CPU instead of computer: "CPU. Central processing unit of the computer system. The CPU contains the main storage, arithmetic unit, and special register groups." ↩
  7. Reference: Computer Architecture, 2011, published by Biyani. Page 58 contains the quiz with the CPU question. The question also appears in MCS-012: Computer Organisation and Assembly Language Programming, 2017. ↩
A visit to the Large Scale Systems Museum
I didn't expect to find two floors filled with vintage computers in a small town outside Pittsburgh. But that's the location of the Large Scale System Museum, housed in a former department store. The ground floor of this private collection concentrates on mainframes and minicomputers from the 1970s to 1990s featuring IBM, Cray, and DEC systems, along with less common computers. Amazingly, most of these vintage systems are working. Upstairs, the museum is filled with vintage home computers from the pre-PC era.
IBM
IBM set the standard for the mainframe computer with its introduction of the System/360 in 1964, a line of computers designed to support the full circle (i.e. 360°) of business and scientific applications. The System/360 evolved into the System/370 in the 1970s and the System/390 in the 1990s. Most of these mainframes filled a data center, but the museum has some smaller S/370 and S/390 mainframes designed for offices. The IBM System/370 9375 (1986; below), is described as a "baby mainframe" or "super-mini computer" for engineering or commercial applications.
IBM System/370 9375. The computer itself is in the middle rack. The left rack has a 3490E tape cartridge storage system, while the right rack holds 9335 disk controllers and disk drives (856 MB per drive).
The System/390 line is represented by the IBM System/390 Multiprise-2003 (1997; below). This mainframe could not boot up on its own, but required a special desktop PC called the Mainframe Service Element (photo) to initialize the mainframe with microcode and start it up.
This low-end IBM System/390 Multiprise-2003 had 1 GB of memory and supported hundreds of simultaneous database transactions.
To support smaller customers, IBM also produced minicomputers, which they called "midrange systems". The IBM System/32 (1975; below) is a minicomputer built into a desk, designed for small businesses. IBM's midrange systems evolved into the IBM AS/400 (1992; photo).
This IBM System/32 had 16 KB of memory and 13 MB of disk storage. It leased for $1200 per month.
The museum has many disk drives and tape drives. One example is the massive 3380E disk drive (below; 1985), providing 5 gigabytes of storage. It's amazing to think that you can now hold a thousand times as much storage in your hand.
The IBM 3380E disk system stored 5 gigabytes of data. The 14-inch disk platter is in the center, labeled "E".
Cray
Computer designer Seymour Cray and his company Cray Research were famed for building the world's fastest supercomputers. The museum has several Cray computers from the 1990s. The Cray YMP-EL supercomputer (1992; below) was an "Entry Level" Cray, costing $300,000. It was built from CMOS chips rather than the fast but hot ECL chips in earlier Crays, allowing it to be air-cooled rather than Freon cooled. The museum also has the related, low-end Cray EL-94, packaged in an ugly box (photo; 1992);
The Cray YMP-EL supercomputer.
The Cray J90 (1996; below) was a popular low-end Cray, an evolution of the Y-MP EL. This one holds 1 GB of memory and cost $300,000.
Cray J 90 supercomputer.
The Cray SV1 (1999; below) followed the J90. It introduced more high-performance features such as a vector cache and multi-streaming. This one has 16 processors and 16 GB of memory, and cost about $1 million.
The Cray SV1 supercomputer.
Digital Equipment Corporation (DEC)
Dave McGuire, curator of the large systems, in front of PDP "Straight 8" minicomputers.
Digital Equipment Corporation was founded in 1957 and became the second-largest computer manufacturer, concentrating on minicomputers. DEC's PDP-8 was a very popular 12-bit minicomputer that essentially created the "minicomputer" category of computers. The first PDP-8 was the Straight-8 (1966; photos above and below), a compact all-transistor computer built from circuit cards plugged into a wire-wrapped backplane.
The "Straight 8" PDP-8 was built from transistorized circuits on small cards.
The PDP-8/E (1969; below) used integrated circuits (7400-series TTL) in place of discrete transistors as did the compact and cheaper PDP-8/A (1974; photo).
PDP-8/E minicomputer. The paper tape reader is at the top, above the front panel. An RK05 DECpack is at the bottom, storing 2.4 megabytes on a removable disk pack.
DEC started producing mainframes in 1966 with the PDP-10, a 36-bit computer that popularized time-sharing. The museum has a DECsystem-2020 (1978), the smallest member of the PDP-10 family.
A DECsystem-2020 mainframe next to an RM02 disk drive. The drive's removable disk packs each store 67 megabytes.
In 1970, DEC introduced the 16-bit PDP-11, which became the most popular minicomputer with about 600,000 sold. The museum has many different PDP-11 models including the PDP-11/05 (1972; photo, console), the fast PDP-11/50 (1972; below, photo), the compact and popular PDP-11/34 (1976; photo), and the PDP-11/44 (1981; photo).
Console of the PDP-11/50 minicomputer.
DEC's PDP-11 evolved into the VAX line of 32-bit computers. Larger and more powerful than earlier minicomputers, these systems were known as superminicomputers. The VAX-11/780 (1978; below) was the first member of the VAX family, and was implemented with TTL chips. The museum has a VAX-11/750 (1980) and the cheap single-cabinet VAX-11/730 (1982; photo), the powerful VAX-6000 (1991; photo), and top-of-the-line VAX-7000 (1992; photo). The VAXstation 4000 Model 90 (1991; photo) was a workstation implementing the VAX instruction set.
The VAX 11/780 "superminicomputer".
DEC started struggling in the 1990s as the market shifted to personal computers. DEC was acquired in 1998 by personal computer manufacturer Compaq, which in turn was soon acquired by Hewlett-Packard in 2002.
Other systems
The museum has systems from many other companies such as Varian, Control Data, Wang, Panasonic, Silicon Graphics, Singer, and Tektronix, but I'll just touch on some highlights.
Data General was a major producer of minicomputers, third behind DEC and IBM. The Data General Eclipse was the successor to the popular Data General Nova 16-bit minicomputer. It is represented in the museum by the Eclipse S/280 (1975; below) and Eclipse S/120 (1982; photo). Data General moved into the microcomputer market with the microNOVA (1977; photo), but it wasn't commercially successful.
Data General Eclipse S/280 minicomputer.
In the late 1970s, Hewlett-Packard was the fourth-largest producer of minicomputers. The HP 2116B minicomputer (1968; photo) was part of the HP 1000 (photo) family of 16-bit minicomputers designed for instrument control and automation. The HP 2645A terminal (below) was part of HP's line of terminals.
HP 2645A terminal
HP 2645A terminal
Another interesting terminal is the Friden Flexowriter from the early 1960s (below). It has a paper tape reader and punch on the left. Flexowriters were often used as console terminals for computers.
Friden Flexowriter
Friden Flexowriter
The Burroughs B80 is a multi-user office minicomputer (1978; below). It has as dot-matrix printer above the keyboard. The computer on display was used by a funeral home, and has a paper product list taped above the keyboard with products such as "Tranquility urn", "Open/Close grave", and "Move dirt more than 25 miles".
The Burroughs B80 office minicomputer.
The collection also includes analog computers, such as the Heathkit H-1 (1950s) which used vacuum tube amplifiers and represented values by signals from -100 to 100 volts. It could be programmed to solve differential equations by wiring the patch board. The museum also has a Comdyna GP-6 (photo), a more modern transistorized analog computer from the late 1960s.
A Heathkit H1 analog computer. Vacuum tubes are on top, the plugboard is in the middle, and potentiometer controls are in the front.
Microcomputers in the Large Scale Integration Museum
Upstairs is the "Large Scale Integration Museum", a large collection of microcomputers of the 1970s and 1980s. The collection focuses on microcomputers before to the IBM PC and x86 processors. Since I'm more interested in the larger computers, I'll discuss this collection briefly, but I don't want to downplay its impressive scope.
Corey Little, curator of the microcomputer collection, in front of Imsai, ASR-33 teletype, Kenbek-1 replica, and Altair.
The first commercial microprocessor was Intel's 4-bit 4004, introduced in 1971. The Intel Intellec 4/40 development system (below), used the 4040 microprocessor (1974), an improved version of the 4004. This system was intended for engineers to develop software for embedded systems using the 4040 chip.
Intel Intellec 4/40 development system. An EPROM socket below the key allowed software to be burned into EPROM chips.
The microcomputer revolution took off when Intel released the 8-bit 8080 microprocessor in 1974, leading to the first commercially successful personal computer, the MITS Altair 8800 kit (1975). In addition to the Altair 8800, the museum has the updated Altair 8800b and the more obscure Altair 680, which uses the Motorola 6800 microprocessor.
Altair 8800 (with the famous manifesto Computer Lib on top), Altair 680, Altair 8800b, and disk drive for Altair.
Single-board computers also helped popularize microprocessors. Companies produced development kits for engineers to experiment with new microprocessors and hobbyists often used them due to their low cost. The museum has several racks of these development boards; the rack below includes the Intel SDK-85 System Design Kit for the 8085 microprocessor, Artisan Electronics Model 85 microcalculator (a single-board scientific calculator that could be interfaced to a microcomputer), Rockwell's 6502-based AIM-65, Synertek's 6502-based SYM-1, and Transputer parallel processor boards.
A variety of development boards and single-board computers.
By the late 1970s, microcomputers became mass-market products, with the introduction of home computers that were more affordable and usable by the general public. The museum has many other popular home computers from manufacturers such as Atari, Sinclair, Radio Shack, Heathkit, and Texas Instruments. The photo below shows part of the Commodore collection.
The Commodore collection includes calculators, Commodore Super PET, Educator 64, PET 4032, and PET 2001
Early portable computers were suitcase-sized and often called luggables. The museum has a large collection including the IBM 5100 (1975; below), Osborne One (1981), Osborne Executive, Osborne Vixen, and Kaypro II, as well as more obscure machines such as the Telcon Zorba and General Electric Workmaster.
The IBM 5100 portable computer was introduced in 1975, six years before the IBM PC. Its keyboard has special characters for the APL language.
Apple is represented by a variety of Apple II, Apple III, Lisa, and Macintosh systems. The collection also includes a NeXTcube, the workstation developed by Steve Jobs in the 1980s after he was forced out of Apple. Steve Jobs returned to Apple when Apple purchased NeXT in 1997, leading to Apple's dramatic rise. The NeXTcube's operating system led to Apple's current macOS and iOS operating systems.
The NeXTcube workstation was packaged in a 1-foot magnesium cube.
The museum has various toys and educational devices that were produced to explain computers, including the CALCULO Analog Computer (1959), Minivac 6010 (1962) created by the father of information theory Claude Shannon, Radio Shack Science Fair Digital Computer Kit (1977), and Digi-Comp 1 (1963).
The collection includes toy computers such as the CALCULO Analog Computer, MINIVAC 6010, Radio Shack ScienceFair Digital Computer, and Digi-Comp 1.
Heathkit introduced the HERO-1 kit robot in 1982, providing a way for hobbyists to experiment with robotics. Nowadays, Arduinos and cheap servos and stepper motors make it easy to build a simple robot, but in 1982, robotics was much more difficult. The HERO-1 kit cost $1500 (equivalent to about $4000 today).
Three Heathkit HERO robots. The HERO 2000 (1986, left) included multiple processors and speech synthesis, while the older HERO-1 robots have a single 6808 processor. The "eyes" are an ultrasonic distance sensor.
The Large Scale Systems Museum contains a remarkable collection of large computer systems and microcomputers from the 1970s to 1990s The museum, hidden behind a storefront on a quiet small-town main street, illustrates an interesting period in computer history. During this time, mainframes, minicomputers, and supercomputers reached their peak and then went into steep decline. Meanwhile, the microprocessor passed through the hobbyist phase and the home computer phase before achieving its dominance. Amazingly most of the systems at the museum are up and running, giving the visitor a feel for the computers of that era.
The museum is open by appointment only; details are here and on their Facebook page. If you ever find yourself near New Kensington, PA (half an hour outside Pittsburgh), get in touch with them. I've only presented the highlights of the museum; more photos are here. I announce my latest blog posts on Twitter, so follow me @kenshirriff for future articles. I also have an RSS feed.
