Understanding Sony IR remote codes, LIRC files, and the Arduino library
This article describes how to understand Sony IR codes and how to get them from the LIRC files. The article is intended to describe codes for use with my Arduino infrared remote library, but the information should be generally applicable. This article is aimed at the hardware hacker and assumes that you are familiar with binary and hexadecimal, so be warned :-)
One key point of this article is that there are three different ways to interpret the same IR signal and turn it into a hex code. Understanding these three ways will allow you to get codes from different sources and understand them correctly.
The IR transmission of the code
When you press a button on a Sony remote control, an infrared signal is transmitted. This transmission consists of a 40kHz signal which is turned on and off in a particular pattern. Different buttons correspond to different codes, which cause the signal to be turned on and off in different patterns.
The following waveform shows the IR code transmitted for STOP on my Sony CD remote control (RM-DC335). When the signal is high, a 40 kHz IR signal is transmitted, and when the signal is low, nothing is transmitted. In other words, the signal is actually rapidly turning on and off when it appears to be on in the figure. (The IR receiver demodulated the signal, so you don't see the 40 kHz transitions.)
IR transmission for a Sony remote control
A Sony IR signal starts with 2400 microseconds on and 600 microseconds off; that's the first wide pulse. A "1" bit is transmitted with 1200 microseconds on and 600 microseconds off, while a "0" bit is transmitted with 600 microseconds on and 600 microseconds off. (This encoding is also called SIRC or SIRCS encoding.)
You may notice the "on" parts of the waveform appear wider than the "off" parts, even when both are supposed to be 600 microseconds. This is a result of the IR receiver, which switches on faster than switching off.
The above waveform represents one transmission of a 12-bit code. This transmission is normally repeated as long as the button is held down, and a minimum of three times. Each transmission starts 45ms after the previous one started. The Sony protocol also supports 15 and 20 bit codes, which are the same as above except with more bits.
For more information on the low-level transmission of Sony codes, see sbprojects.net.
Three ways to interpret the codes
The Sony encoding seems straightforward, but there are several different ways the signal can be interpreted. I will call these official decoding, bit decoding, and bit-1 decoding. Different sources use any of these three, which can cause confusion. I will explain these three decodings, using the previous waveform as an example.
Official decoding
Official Sony decoding
The "official" Sony protocol views the 12-bit code as 7 command bits and 5 address or device bits, transmitted least-significant-bit first (i.e. "backwards"). The device bits specify the type of device receiving the code, and the command bits specify a particular command for this device. In this example, the device bits (yellow) are 10001 when read right-to-left, which is 17 decimal. The command bits (blue) are 0111000 when read right-to-left, which is 56 decimal. The device value 17 corresponds to a CD player, and the command 56 corresponds to the STOP command (details).
Sony 15 bit codes are similar, with 7 command bits and 8 device bits. Sony 20 bit codes have 7 command bits, 5 device bits, and 8 extended device bits.
Bit decoding
Decoding Sony IR code as a sequence of bits
Many IR decoders just treat the signal as a sequence of bits, most-significant-bit first. I will call this bit decoding. Applying this interpretation to the above code, the code is interpreted as 0001 1101 0001 binary, or 1d1 hex, or 465 in decimal. Note that the last bit doesn't really consist of 1200 microseonds on and 600 microseconds off; it consists of 1200 microseconds on followed by a lot of time off. In other words, the transmission is off for 600 microseconds and then continues to be off until the next code is transmitted.
An alternative but equivalent interpretation is to view the code as a 2400 microsecond header, followed by 12 bits, where each bit is off then on (rather than on then off). A "1" bit is 600 microseconds off and 1200 microseconds on, while a "0" bit is 600 microseconds off and 600 microseconds on. This yields the same value as before (232 decimal), but avoids the special handling of the last bit.
Short one bit decoding
Bit-1 decoding
Many IR decoders drop the last bit, which I will call bit-1 decoding. Because the last bit doesn't end nicely with 600 microseconds off, some IR decoding algorithms treat the signal as 11 bits of data, ending with 600 microseconds on as a trailer. In this interpretation, the above code is 000 1110 1000 binary, or 0e8 hex, or 232 decimal. (Note that doubling this value and adding 1 yields the previous decoding of 465.)
Discussion
Is the code really 17/44 or 465 or 232? The official decoding is "right" in the sense that it is what the manufacturer intends. In addition, it reveals the internal structure of the code and the codes make more sense. For instance, the buttons 1-9 have consecutive codes with the official decoding, but not with the others. The other decodings are fine to use as long as you're consistent; the main thing is to understand that different sources use different decodings. My Arduino library uses the second bit decoding interpretation. The different decodings can be converted from one form to another with binary arithmetic.
Getting codes from a remote
Probably the easiest way to get the codes for your device is to use your existing remote control and see what codes it transmits. You can use my Arduino IR library to do the decoding, with the IRrecvDump demo program. Take a 3-pin IR decoder, hook it up to an Arduino, and then you can read the values for each button press on the serial port.
Alternatively, you can look at the transmitted codes with an oscilloscope. For the diagrams above, I used an IR receiver module connected to two resistors (to drop the voltage), connected to the line input of my PC. I used the Zeitnitz Soundcard Oscilloscope program to display the signal. This lets you see exactly what is being transmitted, but you will need to stare at the screen, write down a bunch of 0's and 1's, and convert the binary value to get your codes.
Getting codes from LIRC files
The best source for IR codes that I've found is the Linux Infrared Remote Control project (lirc.org), which has a huge collection of config files for various remotes. (LIRC also includes a large collection of device drivers for many types of IR input/output hardware, and a software library.)
The LIRC config file format is documented at WinLIRC, but I will walk through some examples.
Bit decoding
The RM-S530 LIRC file treats the codes as 12 bits long, using what I call bit decoding:
begin remote
  name  Sony
  bits           12
  flags SPACE_ENC|CONST_LENGTH
  eps            30
  aeps          100
  header       2470   557
  one          1243   556
  zero          644   556
  gap          45076
  min_repeat      2
  toggle_bit      0
      begin codes
          sleep                    0x0000000000000061
          cd_stop                  0x00000000000001D1
This file indicates that each entry is 12 bits long. A header consists of on for 2470 microseconds and off for 557 microseconds. A one bit consists of on for 1243 microseconds and off for 556 microseconds. A zero bit consists of on for 644 microseconds and off for 556 microseconds. Codes are repeated a minimum of 2 more times, with a gap of 45076 microseconds from start to start as the codes are constant length (CONST_LENGTH).
You may be wondering why these time values don't match the official values of 2400, 1200, and 600 microseconds. First, the LIRC data is generally measured from actual remotes, so the real-world timings don't quite match the theory. Second, IR sensors have some lag in detecting "on" and "off", and they typically stretch out the "on" time by ~100 microseconds, shortening the "off" time equally.
The LIRC file then lists the hex code associated with each button. For example the CD STOP code is hex 1D1, which is the same value as described earlier.
Bit-1 decoding
The LIRC file for the RM-D302 remote treats the codes as 11 bits and a trailing pulse. This is what I call the bit-1 decoding:
begin remote
  name  RM-D302
  bits           11
  eps            30
  aeps          100
  header       2367   638
  one          1166   637
  zero          565   637
  ptrail       1166
  gap          45101
  min_repeat      2
  toggle_bit      0
      begin codes
          cd_stop                  0x00000000000000E8
The key differences with the previous file are the ptrail field, indicating a trailing pulse of 1166 microseconds; and the bit count of 11 instead of 12. Note that the code value is different from the first file, even thought the IR transmission is exactly the same. The hex code 0E8 is the same as described earlier under bit-1 decoding.
Pre_data and post_data bits
Some LIRC files break apart the codes into constant pre_data bits, the code itself, and constant post_data bits. For instance, the file for my RM-D335 remote:
begin remote
  name  SONY
  bits            7
  flags SPACE_ENC
  eps            20
  aeps            0
  header       2563   520
  one          1274   520
  zero          671   520
  ptrail       1274
  post_data_bits  4
  post_data      0x8
  gap          25040
  min_repeat      2
      begin codes
          CONTINUE                 0x000000000000005C
          STOP                     0x000000000000000E
This file indicates that each code entry is 7 bits long, but there are also 4 post data bits. This means that after transmitting the 7 bits for the code, 4 additional bits are transmitted with the "post data" hex value 0x8, i.e. 1000 binary.
Putting this together the STOP button has the hex value 0E, which corresponds to the seven bits 000 1110. This is followed by four post data bits 1000, so the total transmission is the eleven bits 000 1110 1000, which is 0E8 hex, the same as before for the bit-1 decoding.
One more thing to notice in this LIRC file is it doesn't have the CONST_LENGTH flag, and the gap is 25ms instead of 45ms. This indicates the gap is from the end of one code to the start of the next, rather than from the start of one code to the start of the next. Specifying a gap between codes isn't how Sony codes are actually defined, it's close enough.
LIRC summary
Note that these LIRC files all indicate exactly the same IR transmission; they just interpret it differently. The first file defines the STOP code as 1D1, the second as E8, and the third as 0E.
What does this mean to you? If you want to get a Sony code from a LIRC file and use it with the Arduino library, you need to have a 12 bit (or 15 or 20 bit) code to pass to the library (bit decoding). Look up the code in the file and extract the specified number of bits. If there are any pre_data or post_data bits, append them as appropriate. If the result is one bit short and the LIRC file has a ptrail value, append a 1 bit on the end to convert from bit-1 decoding to bit decoding. Convert the result to hex and you should have the proper code for your device, that can be used with the Arduino library.
Getting codes from hifi-remote.com
The most detailed site I've found on Sony codes specifically is hifi-remote.com/sony. An interesting thing about this site is it analyzes the structure of the codes. While the LIRC files just list the codes, the hifi-remote site tries to explain why the codes are set up the way they are.
Note that this site expresses codes in Sony format, i.e. most-significant-bit first, and separating the device part of the code from the command part of the code. Also for a 20-bit Sony code, the 13 bit device code is expressed as a 5 bit value and an 8 bit value separated by a period. As a result, you may need to do some binary conversion and reverse the bits to use these codes.
To work through an example, I can look up the data for a Sony CD. There are multiple device codes, but assume for now I know my device code is 17. The table gives the code 56 for STOP. Convert 56 to the 7 bit binary value 0111000 and reverse it to get 0001110. Convert 17 to the 5 bit binary value 10001 and reverse it to get 10001. Put these together to et 000111010001, which is 1D1 hex, as before.
To work through a 20-bit example, if I have a Sony VCR/DVD Combo with a device code of 26.83, the site tells me that the code for "power" is 21. Convert 21 to a 7 bit binary value, 26 to a 5 bit binary value, and 83 to a 8 bit binary value. Then reverse and concatenate the bits: binary 1010100 + 01011 + 11001010, which is a8bca in hex. To confirm, the RMT-V501A LIRC file lists power as A8B with post_data of CA.
To use this site, you pretty much have to know the device code for your device already. To find that, obtain a code for your device (e.g. from your existing remote or from LIRC), split out and reverse the appropriate bits, and look up the device code on the site. Alternatively, there are only a few different device codes for a particular type of device, so you can just try them all and see what works.
This site also has information on "discrete codes". To understand discrete codes, consider the power button on a remote that toggles between "on" and "off". This may be inconvenient for automated control, since without knowing the current state, you don't know if sending a code will turn the device on or off. The solution is the "discrete code", which provides separate "on" and "off" codes. Discrete codes may also be provided for operations such as selecting an input or mode. Since these codes aren't on the remote, they are difficult to obtain.
Other sites
Additional config files are available at irremote.psiloc.com. These are in LIRC format, but translated to XML. The site remotecentral.com has a ton of information on remotes, but mostly expressed in proprietary formats.
Hopefully this will clear up some of the confusion around Sony remote codes, without adding additional confusion :-)
Some similar and confusing Spanish words
While trying to learn Spanish, I find a few Spanish words are similar to other words and keep confusing me. This article summarizes them, mostly for my on benefit in learning to distinguish them, but maybe you'll find it useful too. (Yes, this is a big tangent from my usual blog topics.)
  • llegar - to arrive.
  • llenar - to fill. (My secret to remembering this is that llenar is the root in chile relleno, a stuffed chile.)
  • llevar - to carry.
There are some verb conjugations that are the same or confusingly similar to other words:
  • fuera - outside.
  • fuera - imperfect subjunctive of ser or ir.
  • siento - I sit (from sentar).
  • siento - I feel (from sentir). A bunch of other conjugations are confusing because the present for one is the subjunctive for the other: sientas/sientes, sienta/siente, sienten/sientan, sentamos/sentimos.
  • ira - anger.
  • irá - future of ir.
Detecting an IR Beam Break with the Arduino IR Library
One reader asked how to use my Arduino Infrared Library to detect breakage of an IR beam. The answer was too long for the comments section, so I've extended into a blog post. One straightforward way is to use the library to modulate an IR LED at 38kHz, and use a standard IR detector module to detect the signal. The output from the module can be simply read as a digital input.
Here is a simple sketch to do that. The IR LED is connected to pin 3 through a 100 ohm resistor, the detector is connected to pin 2, and a status LED is connected to pin 13 (if your Arduino board doesn't have it already.) To create the modulated output, simply call irsend.enableIROut(38); to set the PWM to 38kHz, and then irsend.mark(0) to send a mark (i.e. turn the output on). The loop simply reads the input from the detector, inverts it (since the detector is active-low), and writes it to the status LED.
#include <IRremote.h>
#define PIN_IR 3
#define PIN_DETECT 2
#define PIN_STATUS 13
IRsend irsend;
void setup()
  pinMode(PIN_DETECT, INPUT);
  pinMode(PIN_STATUS, OUTPUT);
  irsend.mark(0);
void loop() {
  digitalWrite(PIN_STATUS, !digitalRead(PIN_DETECT));
You should see the pin 13 LED light up when the IR receiver detects an infrared signal, and go dark when the receiver does not detect an infrared signal. The circuit is basically trivial, but there's a schematic at my original article if you need one. The following picture shows the detector setup. Note the illuminated status LED.
IR detector circuit
If the circuit doesn't work, first use a cell phone camera to verify that the infrared LED is lit. If the LED is not lit, try reversing it. Here's my cellphone's view of the illuminated LED:
illuminated infrared LED
Next, point a TV remote control at the detector and make sure the status LED flashes. If the status LED doesn't come on, make sure you wired the detector properly, and connected to input 2 of the Arduino. If the status LED won't turn off when you break the beam, you probably aren't blocking the IR signal well enough. The detector is very sensitive, and IR bounces off many things, so you may need to separate the LED and detector by several feet and make sure you're fully blocking the IR beam. Note that the library assumes you're using a ATmega168/328, so you're on your own if you have a different processor.
The tricky part of this is the optics - figuring out how to set up the LED and receiver so the beam gets interrupted when you want it to. Also, you'll probably want to modify the detection logic to do something more interesting than just set the status LED, but that's left as an exercise for the reader :-)
Fixing my Concertmate MG-1 Synth
I pulled my Concertmate MG-1 synthesizer out of storage for my next Arduino project (to be described later), only to find that it wasn't working quite right. This posting briefly describes how I fixed it, in case anyone else has a similar problem.
Concertmate MG-1 Synthesizer
The main problem with the MG-1 was a loud click (a bit like a kick drum) when I pressed or released a key. It sounded suspiciously like a DC signal being applied to a speaker. The second problem was that when I set the contour for an attack and decay, the note got louder and softer, but as the note got softer it was replaced with a buzz at the frequency of oscillator 1.
Conveniently, the Service Manual is available online. I studied it and the schematic, and my first guess was that there was a DC offset going into the CA3080 amplifier, resulting in an amplified DC signal in the output. The CA3080 is not a normal amplifier but an operational transconductance amplifier, an unusual amplifier where the current on a control input controls the amplification of the input signal (more info). In this case, it is used as a voltage-controlled amplifier, allowing the contour signal to control the output.
In the schematic below, op-amps U10A and U10B feed the differential output signal into the 38080 amplifier. Pin 5 of the 3080 receives the contour signal to provide the attack and decay when you press a key. This signal controls how much the inputs are amplified. The output goes into the master volume control, and then to the synthesizer outputs. If there's a DC offset between the input pins 2 and 3, there will be an amplified DC offset at the output.
MG-1 Output Schematic
Fortunately, there is a VCA Balance Trim adjustment to trim any DC offset, and the manual describes how to adjust this. I opened up the MG-1 and adjusted this, but unfortunately it made no difference at all.
Next, I stared at the schematic for the contour generator that feeds into the CA3080 amplifier, but couldn't see how that could be going wrong. I measured the inputs to the CA3080 with an oscilloscope and found they all seemed normal. However, the output showed a 3.75V DC jump when the key turned on, which explained the click. In addition, the contour input showed it was picking up some crosstalk from the oscillator 1 trace that runs next to it, and this was being amplified into the buzzing noise.
All signs pointed to a problem with the CA3080 amplifier chip, which was somehow amplifying a big DC signal. Unfortunately, the CA3080 is no longer being manufactured and is hard to obtain. Fortunately, by some bizarre twist of fate, I happened to have one in my rather small box of parts.
The picture below shows the two main circuit boards. The upper board is the sound generation, filtering, and amplification, while the lower board has the power supply, keyboard, control, and polyphonic sound.
MG-1 internals
I removed the circuit board, soldered in the new CA3080, got the switches centered just right so the circuit board could be replaced, and put it back together. Unfortunately, I didn't get any output at all. I was afraid I'd somehow destroyed my rare CA3080 chip, but fortunately discovered that if the switches are in intermediate positions, you don't get any signal. I returned the switches to their proper positions and all was well.
In conclusion, I succeeded in fixing my MG-1 and getting that lovely, rich Moog sound.
