If you're looking for a comprehensive dual-boot tutorial, try apc or Loko.
My setup
I'm running Windows 7 and Fedora 11 Linux on a Gateway SX2800.Partitioning
I use the Gnome Partition Editior (GParted). Windows 7 conveniently includes a partition software under Disk Management, but inconveniently it can't shrink a volume by a large amount.
My partitioning setup is a bit crazy. Because I bought my computer before Windows 7 was released, I used Windows 7 beta until I got the official upgrade DVD. One unpleasant surprise is you have to reinstall to get from the beta to Windows 7 Home Premium; you can't just upgrade. I had an empty E:
partition, so I installed the offical release there, transferred my files with Windows Easy Transfer, and then spent an evening reinstalling all my software. I store most of my data on a FAT32 partition D:
to avoid messing around with NTFS on Fedora.
You'll probably want something simpler than what I have, but my partition table is:
$fdisk /dev/sda ... Device Boot Start End Blocks Id System /dev/sda1 1 1698 13631488 27 Unknown /dev/sda2 * 1699 14445 102390277+ 7 HPFS/NTFS /dev/sda3 14446 27193 102398310 7 HPFS/NTFS /dev/sda4 27194 77825 406701540 5 Extended /dev/sda5 27194 28289 8803588+ 82 Linux swap / Solaris /dev/sda6 28290 70176 336457296 b W95 FAT32 /dev/sda7 70177 77825 61440561 83 Linux
sda1
is a mysterious Gateway recovery partition, sda2
is C:
, sda3
is E:
, sda6
is D:
for most of my data, and sda7
is the Linux partition.
/etc/fstab
/dev/sda7 / ext3 defaults 1 1 tmpfs /dev/shm tmpfs defaults 0 0 devpts /dev/pts devpts gid=5,mode=620 0 0 sysfs /sys sysfs defaults 0 0 proc /proc proc defaults 0 0 /dev/sda5 swap swap defaults 0 0 /dev/sda6 /d vfat auto,rw,user,sync,exec,dev,suid,uid=500,gid=500,umask=000 0 2
My GRUB config
default=1 timeout=5 splashimage=(hd0,2)/boot/grub/splash.xpm.gz hiddenmenu title Fedora (2.6.30.9-96.fc11.i586) root (hd0,6) kernel /boot/vmlinuz-2.6.30.9-96.fc11.i586 ro root=/dev/sda7 rhgb quiet initrd /boot/initrd-2.6.30.9-96.fc11.i586.img title Windows 7 rootnoverify (hd0,1) chainloader +1Note the off-by-one:
(hd0,6)
boots off sda7
. For Windows, you need to specify the partition with the Windows boot loader; if I try to boot E:
directly with (hd0,2)
, I get BOOTMGR IS MISSING.
Editing the GRUB config from Linux rescue boot
Invariably I end up unable to boot Linux from my disk. To fix this, I boot from my Linux CD and then fix the GRUB config. The following assumessda7
is the Linux partition:
mount /mnt /dev/sda7 cd /mnt/boot/grub vi menu.lst grub-install --root-directory=/mnt /dev/sda
Editing the Windows boot loader configuration
If you have multiple versions of Windows, you'll need to configure the Windows boot loader throughbcdedit
: details.
Other random errors
My Fedora Core boot failed with an infinite loop of "init: ttyx respawning too fast, stopped". The solution was to changeselinux=enforcing
to selinux=permissive
in /etc/selinux/config
2 comments:
About the "BOOTMGR IS MISSING."
I also had that error.
It seems that Windows 7 is either using existing NTFS od FAT Partitions for its bootloader (probably to avoid breaking dual-boot installations with older windows versions - I dunno) OR it creates an extra mini Partition for its bootloader if it is the first System installed on the machine.
However, the Partition where the "main body" of your Windows 7 is installed is not the one you need to put into grub. You need to find out where W7 mislaid its bootloader.
I also had the same error before.
Here's the solution:
edit the linux "/boot/grub/grub.conf" like this :
title Windows 7
root (hd0,0)
chainloader +1
because Win 7 boot from the first partition /dev/sda1 which is 100MB size.
