The example
This example implements a simple Ajax input autocompleter and dynamic page update. For the autocompleter, as soon as you enter a few letters into the input, it provides a list of matching terms. As soon as you select a term, the page is dynamically updated with associated data, as in the following screenshot:
For the purposes of the demonstration, the content is information on the countries of the world, obtained from the CIA World Factbook.
To summarize how it all works: When you enter characters in the input field, the script.aculo.us autocompleter JavaScript sends the charaters to the Arc server, which returns the autocomplete suggestions. The autocompleter JavaScript displays the suggestions on the page. When you select a country, the updater JavaScript does three separate requests to the Arc server, to request the population, area, and capital. When the responses arrive, they are inserted into the page.
In more detail, the autocompletion is performed by Ajax.Autocompleter, and the dynamic updating is performed by Ajax.Updater. The control flow is:
The
Ajax.Autocompleter
associated with theautocomplete
input andautocomplete_choices
div sends inputs to/auto_complete?prefix=chars
. - The Arc handler sends back a formatted list of autocomplete candidates, e.g.
<ul><li>Iran</li><li>Iraq</li><li>Ireland</li></ul>
. - The
Ajax.Autocompleter
displays the candidates in theautocomplete
div. - When an autocompletion is selected, the
update
JavaScript function starts threeAjax.Updater
instances, which send an Ajax request to URL/getcontents?field=population&name=value, and similarly for area and capital in parallel.
- The Arc handler for
getcontents
returns the desired contents.Ajax.Updater
puts the contents into thecontents
div. - The Arc handler for
Running the example
First set up the necessary files.- Download ajax.zip and uncompress it into the
same directory that Arc runs in. This zip file provides
ajax.html
,ajax.arc
,data.arc
, andautocomplete.css
. - Download the script.aculo.us library files from script.aculo.us. Copy the
.js
files fromlib
andsrc
into the same directory that Arc runs in.
ajax.arc
file, and start the web server.
arc> (load "ajax.arc") arc> (thread (serve 8080)) arc> ready to serve port 8080Then go to http://localhost:8080/ajax.html. (Unfortunately I don't have a live demo on a public machine. If anyone sets one up, let me know and I'll add a link here.)
Start typing in the box, and you should see a dropdown with autocompleted choices. Click one, and the code will be displayed below asynchronously.
The Arc code
The Arc server code is inajax.arc
. Two Arc handlers are implemented to provide the client-side Ajax support. The first, auto_complete
receives the current input contents and returns a list of up to 10 autocompletion candidates formatted in HTML.
The second handler, getcontents
returns the dynamic content for the page, from the database
table. Note that the handlers do nothing particularly special to make them "Ajax"; they are standard Arc web handlers based on defop
and can be accessed directly through the browser. See Arc Web Server for more information on web serving with Arc.
(defop auto_complete req (let prefix (downcase (arg req "prefix")) (prn (to-html-list (cut (startselts prefix keylist) 0 10))))) (defop getcontents req (with (field (arg req "field") name (arg req "name")) (if (is field "population") (prn ((database name) 1)) (is field "area") (prn ((database name) 2)) (is field "capital") (prn ((database name) 3)))))The handlers use a couple helpers;
startselts
returns the elements that match the autocomplete prefix and to-html-list
wraps the elements in HTML list tags.
; Returns a list of elements that start with prefix (def startselts (prefix seq) (rem [no (begins (downcase _) prefix)] seq)) ; Wraps elts in HTML list tags (def to-html-list (elts) (tostring (prall elts "<ul><li>" "</li><li>") (pr "</li></ul>")))The actual content is obtained from
data.arc
, which contains the information on each country as a list of lists.
("United States" "301,139,947" "9,826,630" "Washington, DC")Some simple code converts the list into a table called
database
indexed by country for easy lookup, and generates a sorted list of countries for use in autocompletion:
(= database (table)) (w/infile inf "data.arc" (let datalist (sread inf nil) (each elt datalist (= (database (elt 0)) elt)))) (= keylist (mergesort < (keys database)))
For some reason, the default Arc web server srv.arc
doesn't support .js
files. The ajax.arc
file modifies the server slightly to support these files:
(= (srv-header* 'text/javascript) "HTTP/1.0 200 OK Content-Type: text/javascript; charset=UTF-8 Connection: close") (def static-filetype (sym) (let fname (string sym) (and (~find #\/ fname) (case (last (check (tokens fname #\.) ~single)) "gif" 'gif "jpg" 'jpg "css" 'text/css "txt" 'text/html "html" 'text/html "js" 'text/javascript ))))
Debugging
Several things can go wrong when trying to run the example. If the initial page doesn't load at all, something is probably wrong with the Arc server. If no autocompletion happens, the JavaScript may not be loading, or the Arc server may have problems. If the autocompletion shows up as a bulleted list, the CSS file is probably not loading.The Arc code can be debugged in several ways. The first is to access the handlers directly. The autocomplete handler http://localhost:8080/auto_complete?prefix=a should return a bullet list of autocomplete suggestions. The contents handler: http://localhost:8080/getcontents?field=area&name=Algeria should return the dynamic contents value.
The Arc code can also be debugged by strategically inserting print statements such as:
(write req (stderr))This will display the request on the Arc console.
To debug Ajax, you can use Firefox plugins Live HTTP Headers and Firebug. Live HTTP Headers lets you see the headers between the browser and the server, and is very helpful to determine if something is failing. Firebug allows much more in-depth JavaScript debugging. The browser's JavaScript console is also useful to see JavaScript errors.
This article has just scratched the surface of script.aculo.us and Ajax. More information is available at the script.aculo.us website or in books.
