Continuations made difficult
For a challenge, I translated the "mondo-bizarro" Arc Continuation Puzzle into Java.
Why would I do that? Because I can :-) But seriously, using continuations in a language entirely unsuited for it is a good way to experience the tradeoffs of different styles of languages, as well as a way to learn more about how continuations work.
This code is entirely different from my Arc version, mainly because in the Arc version I decided to see if the throw/catch idiom could replace call/cc; the Java code is much closer to the original Scheme. Because Java doesn't have first-class continuations, I used the Continuation-passing style of explicitly passing continuations around. Then call/cc is simply replaced with use of the current continuation.
Because Java doesn't support first-class functions, every continuation function needs to be wrapped in a class that implements an interface, which I unimaginatively call Continuation. The "let" also turns into an object creation, resulting in another class. This results in a fair bit of boilerplate to handle all these classes compared to the Scheme code, but the Java code maps recognizably onto the Scheme code.
On the whole, mondo-bizarro worked better in Java than I expected; no Greenspunning required. It produces the expected 11213 output, proving it works. I think the Java code is actually easier to understand, since everything is explicit.
I have also found it entertaining to implement some of the complex SICP exercises in Java; maybe I'll post details later.
(The title of this article is, of course, a homage to Mathematics Made Difficult.)
Here's the code.
 * Mondo-Bizarro ported to Java.
 * Based on mondo-bizarro by Eugene Kohlbecker
 * ACM SIGPLAN Lisp Pointers, Volume 1, Issue 2 (June-July 1987) pp 22-28
/* Original Scheme code:
(define mondo-bizarro
  (let (
        (k (call/cc (lambda (c) c)))
    (write 1)
    (call/cc (lambda (c) (k c)))
    (write 2)
    (write 3)))
interface Continuation {
  public void run(Continuation c);
public class Mondo implements Continuation {
  public static void main(String argv[]) {
    Continuation c = new Mondo();
    c.run(c);
  public void run(Continuation c) {
    Continuation let = new Let();
    let.run(c);
  class Let implements Continuation {
    Continuation k;
      k = c;
      System.out.println("1");
      k.run(new C2());
    class C2 implements Continuation {
        System.out.println("2");
        k.run(new C3());
    class C3 implements Continuation {
        System.out.println("3");
Continue reading...
